MaxPayne problem - POMOC
Mali HoBiT
CPU & Cooler
i7 14700kf P6.0/E4.6GHz Heatkiller IV waterblock
Matična ploča
Asus Z790 itx
RAM
G.Skill 2x24GB Patriot 8000MHz
GPU
Sapphire 6800XT EK waterblock
Storage
WD Black 850 1TB & Samsung 980Pro 2TB
PSU
Phanteks Revolt SFX 850w Platinum
Kućište
SSUPD Meshlicious, custom loop
Monitor
LG 38WN95C-W
Miš & tastatura
Keychron K7 max & Keychron m3 Metal
Ostale periferije
CP1500EPFCLCD
e poceo ja da igram ovu slatku igru i vidim meni nesto cudno...
zvuk,zvuk je bre ubrzan 5x!!!,sva konverzacija zvuci ko svadja snorkijevaca!!! :mrgreen: (mislim stvarno je smesno,ali nemozes da se uzivis ko covek,a o pracenju radnje da ne pricam)
moram li da menjam zvucnu(DiamondMS mx500-aureal2 cip) ili sta???
iz read me-ja :
Unsupported Sound Cards:
Aureal Vortex 1 & 2 based sound cards such as Diamond MonsterSound MX300 or Turtle Beach Montego are unsupported. You may be able to run the game by going to Control Panel, then double-clicking on "Aureal Vortex Audio". On the first tab, there is a check box for disabling 3d hardware audio. Make sure that this box is checked. Also, see above for instructions on reducing hardware acceleration level to basic. Problems with these cards may show up as crashes in "au30wave/asp4ware", or generic system instability.
a da... vidis... to mi nije palo na pamet 😀 ,hvala
Poz.
