Concise Free Ride Extreme Solutions
for Mafia by Illusion
version 1.55 9/29/02
by HiRisque
[email protected]
The Missions are listed in the order the bonus cars have in the Free Ride Prototype list.
Sniper Mission - Manta Prototype
This mission involves a Manta Prototype that is parked on the front steps of a building in the center of downtown. There is a sniper rifle next to it and 3 enemy snipers who start shooting as soon as you take the mission. Run towards
the cars right side jumping as you go. Pick up the rifle and head back towards the building, go around the left to the back of the building. You must jump when you're moving as the snipers are very good. Continue around the back of
the building. As you do you will notice a sniper across the street from the drivers side of the Manta. He is up high on the building. Kill him and continue around the building. The second sniper is directly across the street from the
front of the Manta halfway up the center of the building. The last sniper is across the street from the passenger side of the Manta. He is on the short black building by it's sign.
Invisible Man Mission - Bolt Thrower
This mission starts by Morello's Bar. It involves following an invisible man who is relatively difficult to see as he tries to escape. Although he can run a little faster than you he pauses frequently. The easiest place to lose him is
as he gets on the elevated train. It is best to do this mission first if you are trying to save all the cars in the Extreme Free Ride Home gamesave. It seems that if the invisible man can see a dead body somewhere on the map he
will stop moving at certain points.
Sea Monster Mission - Hotrod
This mission starts in the north west corner of the square in Chinatown. You are given a SW Model 27 with six rounds of ammo. You must rescue a fair damsel chained to the rocks on the beach in south west Downtown before she is devoured
by a sea monster. This location is where Paulie had his gun jam in the Morello assasination attempt. It helps to use a fast bonus car for this mission such as the Flamer as you are not given much time. Take the Terranova bridge and go
past the armory, turn right and go south by the most direct route to the beach. When you get to the parking lot get out of the car and go left by way of the rocks to get above the fair damsel. Shoot off the lock to free her.
Gangster Killing Mission - Black Dragon 4WD
This mission starts in the Works Quarter in front of the "agreed upon place" from the Cigar Heist Mission. Upon excepting the challenge dive for the Thompson machine gun in front of you and then proceed to kill about 8 gangsters
placed strategically around the balconies of the yard and alley in this area.
UFO Chase Mission - Mutagen FWD
This mission starts at the "T" dead end in the center of the Works Quarter. You must follow a UFO. Drive over by the alien and the UFO will make it's first move. The UFO moves to a new location each time you go under it and then waits
until you get under it again. It is easy to lose sight of the UFO however it makes a sound you can hear when you are close to it. It goes through Little Italy then to Central Island over the Central Island Tunnel. It crosses from
Central Island to a point due west of the one way street by the Downtown Church. It goes straight over the Oakwood Church to the front of Oakwood Junior High School. It then goes to its last stop at the Lighthouse. You are given a large amount of time to complete the mission.
Flame Spear Circuit Mission - Flame Spear 4WD & Flamer
The Flame Spear 4WD is located in the same alley that you boosted the truck for the Cigar Mission. This involves following a timed course defined by magenta smoke pots. The mission ends at the south side of the Municpal Building. If you make it you also get the Flamer, a nice little Celeste based hotrod. As far as I can tell if you want to put the Flame Spear 4WD someplace in your Extreme Free Ride Home gamesave, do not get out of the car after you win the mission. You can not get back in the car after you exit. I put mine by a filling station as a display piece.
Timed Explosive Truck Mission - Masseur
The start point for this mission is in a parking lot north of the Hoboken entrance to Oak Hill. You must drive the Truck that is loaded with explosives to a location in the Works Quarter. It is a timed mission, you really have to
hustle and by all means be careful as a collision will result in the truck exploding. The best route is a follows, turn left, go to end of the street and turn left, go straight to the end and turn left. Make the right hand corner and follow the street over the Guilliano Bridge. Make the turns to go over the West Marshall Bridge. Go straight to the end of the street and then go left then
right down the alley shortcut. Go straight out the alley and where the street ends go through the loose doors to the next alley shortcut (if you haven't knocked them down prior to this). Be careful in the dirt part of the alley. As
you come to the end of the alley you will see the Massuer across the street on your right.
Speed Explosive Truck Mission - Masseur Taxi
This mission starts in the parking lot where Paulie had his gun jam in the Morello assassination attempt. You must drive the truck loaded with explosives to a location in the Works Quarter. You have a limited time to attain 30mph and
after that you have to keep it above 34mph or the truck will explode. Although there are many routes you can take I will give you the most direct possible route. Get in the truck and accelerate towards the East Marshall bridge. Turn
on the speed limiter. Go over the bridge and then turn right (turn the speed limiter off before you go over the bridge and let the speed build to 50 mph, then when you are on the bridge turn it back on). Remember to make wide turns
and not to hit anything. Next turn left and go west on the divided street. A block before you have to turn right and go north, turn the speed limiter off again. This is to carry enough speed while going over the West Marshall Bridge. When you're on the bridge turn the limiter back on. Take the 3rd left after the bridge and then the next right. You are going to a location just past the sheds that are west of the concrete mixing towers. This is one of the toughest missions to beat.
Airplane Chase Mission - Demoniac
This mission starts from the small dirt road in easternmost Hoboken. You must drive a Celeste Marquee 500 that has a bomb in it. The bomb goes off if you get more than 200 meters from the airplane that is passing over. To win this
mission it is essential to drive as fast as possible and be sure of where you are going. Take the road in front of you straight out until it ends and go left. Take this road over the Giuliano Bridge. Take the first right, then go left
through the alley under the el train. Turn right and go through the Central Island Tunnel. Go straight down this road and as it turns left. Make the next right (it helps to cut the corner) and then it is a straight shot to the end.
Vision Distortion Race Car Mission - Crazy Horse
You must drive a Trautenberg Racing from the start point in the alley west of Yellow Pete's, through a series of points to the finish location in front of the Police Station. This is a timed mission and your vision is distorted by speed. The trick is avoiding collisions and watching the map for your turns.
