1. Phone seems to be working fine.
2. Menus load a lot faster. Delay in response is hardly noticeable.
3. JAVA applications run much better and smoother. Better support for JAVA applications. Some games that did not run on R1A now runs on R3C. Java performance is remarkably improved, both loading time and runtime performance. Monster Land is playable on it now.
4. Playback on recordings are now played on the loadspeaker. No need to listen to recordings as if you are listening to a phone call. This new feature does NOT act like a speakerphone. It only playbacks recorded audio on the loudspeaker.
5. Clock on standby screen has more rounded font.
6. Now you can copy individual phonebook entries from the SIM to the Phone's memory. This is done via Phonebook->Advanced->Call from SIM->then select the contact you want->More->Copy to phone. No facility yet to copy individual contacts from phone to SIM.
7. Camera looks pictures look sharper and better. In R1A, only brightness control (Up and Down joystick on camera mode) is available. Now, saturation control (Left and Right on joystick on camera mode) is already available.
8. My sounds memory usage is now reported. In R1A, the total memory is reported as "0kb" and you have to click on the My sounds to get a listing of sounds with the corresponding memory usage per sound.
9. Editing (add effects) pictures process faster. NEW TRICK HERE: I found that when I edit a picture using picture editor in the phone, the saved file size is smaller. My sample started at 50kb then after adjusting the brightness, the picture is now 36kb. Reducing picture size by editing them on phone reduce the quality significantly. I found that the "brightness" effect has the least effect on picture quality. So what I do is to first insert a picture that is darker by about 40% then edit in the phone with the picture effect.
10. Turning ON the phone makes the same single "clang" sound just like in turning OFF the phone. Before, when I turn on my phone, I just see the little Red LED light a little bit and here a very faint wave type of sound. Turning OFF the phone gives me this "clang" sound. Now, the "clang" sound is there on both ON and OFF.
11. Animated gif images now playing much faster than before. I tested with a 120x115 gif, the frame rate is about 60% of that on PC. I remember it was about 10%.
12. The "increasing volume" effect while playing ring tones in "My sounds" is removed.
13. It couldn't display Chinese in java Canvas. It can now. It's probably because of "prgCXC125585_CHINA_2". Liuyidaocn is from Singapore and the new firmware on his T610 is R3C004_prgCXC125585_CHINA_2. Please note that the original post is based on my firmware of R3C004_ASIAN_LATIN_3.
14. "Resend" text messages. If you look in "Sent" text messages, highlight a sent message and press "More" and there is now a facility to "Resend" a text message. Note that this is different from "Forwarding" a text message.
15.When vibrate is ON, calendar and timer alarms also vibrate.
16.T9 text input mode: When replying to message, pressing the joystick accepts the word. When not in T9, joystick press sends message.
][V][ATRIX™ je napisao(la):
Ima il neko problema da skida kolor slike sa c100??
Probao sam kod burazera na c100 i 063 karticom da preko gprsa skinem bilo kakvu kolor sliku i
kad krene da je skida prijavi gresku unknown file format ili tako nesto slicno.I na ovom sajtu
koji sam napisao imaju slike za c100 ali i njih nece da skine niti da ih prikaze!Crno bele slike
sasvim normalno prikazuje i skida i melodije i java igrice!!Sve moguce opcije u meniju sam isprobao i nista!!
Kod mene slike skidam bez problema ali neke kada ih skinem ne mogu da ih gledam->telefon odmah blokira i primoran sam da vadim bateriju i opet palim telefon...CUDNO!Koliku memoriju ima ovaj telefon,u jednom trenutku sam imao cak oko 50 slika,4 igre i oko 5 melodija(bez racunanja
onih sto su vec bili u telefonu)!
....Inace telefon je stvarno OK za te parice...
Koju karticu imas?Da ne zeza nesto mobtel
