Lenovo 10.1" Ice Cream Sandwitch
IzNoGooD
Ocekuje se do kraja godine. Specifikacije:
Ice Cream Sandwich along with NVIDIA's Tegra 3 are on the menu. Other features include 2GB 1,600MHz DDR3 RAM, a standard USB host socket (covered by a not-so-elegant pop-out flap), a back-facing camera of unknown resolution, a "Special Fusion-Skin Body" and, most interestingly, a fingerprint scanner that apparently doubles as an optical joystick on the seemingly flat backside -- only time will tell whether this layout makes sense. Our source hasn't spilled any info on the dimensions and weight, but judging by the photos in our gallery, this 1.6GHz quad-core slate should be significantly thinner than the IdeaPad K1 or LePad sitting underneath. As always, you'll hear from us as soon as we find out more.
Lepo zvuci, ali DDR3 na 1600MHz... Blago nemoguce.
mislim da su mislili na CPU da je 1600MHz i da je RAM DDR3
Najverovatnije. Palo mi je na pamet da je LPDDR3 na 800, sa dvokanalnim memorijskim kontrolerom, pa su se malo igrali u marketingu, ali Tegra3 i dalje ima samo jedan mem. kontroler.
