Kubuntu, card reader
danijel00
Ubacio sam novi interni card reader (onaj mnogo in 1), reader lepo radi pod windowsima, ali uvek ima dodeljena slova za svaki drive, sto me malo nervira, ali sam se nadao da ce lepo raditi pod linuxom...
avaj, ubodem karticu i drive sija, ali ne uspevam ni za zivu glavu da je mountujem... gledao sam malo po googlu, ali se nisam snasao...
nadam se nekom relativno normaalnom nacinu da mountujem karticu |)), pa ko ima ideju neka vice...
kad ubodem externi microsd (koji se ponasa kao obican flash), on se automountuje i lepo radi, a ovaj interni me zeeeezaa...
(lupam 200 na sat): vidi sta kazu komande
lsusb
i
dmesg
Mozda izvuces nesto korisno. A vidi da li ces nesto korisno da izvuces iz 'sudo fdisk -l', mozda vidis kako prepoznaje karticu (/dev/sdx), pa onda to probas da montiras.
(spomenuo 'mozda' i 'vidis' 20x :()
pozz
Probao ovo: http://linux-sxs.org/hardware/flashreaders.html
Problem je kad probam mount /dev/sdx /media/card
on kaze Mount: uknown device, za svaki... idu od sdc do sdg
znam da citac vidi ovu karticu, probao sam...
lsusb kaze
Bus 003 Device 002: ID 046d:c517 Logitech, Inc. LX710 Cordless Desktop Laser
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 05e3:0716 Genesys Logic, Inc.
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
dmesg kaze
[ 70.924568] usb-storage: device scan complete
[ 70.925278] scsi 8:0:0:0: Direct-Access Generic STORAGE DEVICE 9732 PQ: 0 ANSI: 0
[ 70.926030] scsi 8:0:0:1: Direct-Access Generic STORAGE DEVICE 9732 PQ: 0 ANSI: 0
[ 70.926778] scsi 8:0:0:2: Direct-Access Generic STORAGE DEVICE 9732 PQ: 0 ANSI: 0
[ 70.927527] scsi 8:0:0:3: Direct-Access Generic STORAGE DEVICE 9732 PQ: 0 ANSI: 0
[ 70.928286] scsi 8:0:0:4: Direct-Access Generic STORAGE DEVICE 9732 PQ: 0 ANSI: 0
[ 70.928567] sd 8:0:0:0: Attached scsi generic sg3 type 0
[ 70.928624] sd 8:0:0:1: Attached scsi generic sg4 type 0
[ 70.928676] sd 8:0:0:2: Attached scsi generic sg5 type 0
[ 70.928724] sd 8:0:0:3: Attached scsi generic sg6 type 0
[ 70.928775] sd 8:0:0:4: Attached scsi generic sg7 type 0
[ 70.933666] sd 8:0:0:0: [sdc] Attached SCSI removable disk
[ 70.934402] sd 8:0:0:1: [sdd] Attached SCSI removable disk
[ 70.935049] sd 8:0:0:2: [sde] Attached SCSI removable disk
[ 70.935778] sd 8:0:0:3: [sdf] Attached SCSI removable disk
[ 70.936527] sd 8:0:0:4: [sdg] Attached SCSI removable disk
no to sam sve vec znao...
fdisk -l ne kaze nista pametno... izlista samo hardove..
Idem da restartujem masinu u windows da probam jos jednom karticu i da vidim po redu koje slovo dodeli ovoj sto sam gurnuo trenutno...
Stvano nemam pojma... trebalo bi da uspe da ga montira cim ga prepoznaje (dmesg). Probaj ovu bolesnu stvar: ubodi citac u drugi USB port. Meni je jednom ovo resilo problem sa digitalcem (montiram ga, sve je u redu, a kad pocne kopiranje zakuca se posle ~300KB; izbacim usb kabl od ispred i nakacim ga pozadi i sve lepo radi... cudno al' ***a...)
interni je citac...
U medjuvremenu, dok sam se igrao sa mountovanjem, je kartica prosto ispustila dusu, dal je suvise dugo boravila u citacu, pa joj se nije svidelo ili citac ne voli micro sdhc kartice ili se nije slagala sa linuxom, ne znam, ali eto imam jedan komad unistenog hw-a vise... srecom sam neki dan pocupao vecinu slika sa nje (fali mi od zadnjih par dana...). Da stvari budu tuznije citac je lian li i cena mu je u skladu sa pedigreom, a mogu samo da preporucim svima da ga obidju u sirokom luku... stvarno me zanima da li neko jos pravi postene interne citace...
edit Probao sam jos 2 kartice...
jednu micro sd 1gb i jos jednu sdhc (full size) class 6 i obe rade bez problema i automatski su se mountovale... ***, definitivno mislim da joj se nije svidjalo sto je ostala skoro 2 sata u masini dok sam ja gledao neku seriju i cackao mount...
