Kordinatni sistem u Wordu
Stefan1
Pozdrav,
moze li neko da mi pomogne kako najlakse da napravim kordinatni sistem u Wordu sa X i Y osama... nikad do sad to nisam radio...
Hvala unapred...
Pogledaj ovo, nisam siguran da ti bas ovako nesto treba ali je meni par puta dobro dosao.
http://www.padowan.dk/graph/
Interact with other programs
You can save the coordinate system with graphs as an image on disk either as a bitmap (bmp), Potable Network Graphics (png), JPEG, metafile (emf) or Portable Document Format (PDF). You may also copy the coordinate system into another program, e.g. Microsoft Word, either as a normal image or as an OLE object, which may be edited later by double clicking on it.
