Aleksandar@1389
Potrebna mi je pomoc oko kucista koje planiram da uzmem kod nas na kredit.
Namena kucista je net,youtube,word/exel i Geforce now.
Monitor mi glumi TCL C735.
Potrebno mi je sto jeftinije resenje,ako je moguce da ne bude mnogo bucno.
SDD plafon 250gb,ne skidam vise nista,prostor mi nije potreban...
Igre igram samo preko Geforce Now,odusevljen sam kako ovaj servis radi. Za ovo sam koristio neki racunar stariji od mene koji je pre par dana zavrsio svoje.
Recommended for GeForce NOW Ultimate Membership
GeForce NOW requires at least 45Mbps for streaming up to 3840x2160 at 120 FPS, at least 35Mbps for streaming up to 3440x1440/2560x1440/2560x1600 at 120 FPS and at least 35Mbps for up to 1920x1080 at 240fps. We also recommend a hardwired Ethernet connection, or a 5GHz wireless router. AV1 streaming requires a capable GPU. Please read this knowledge base article for more information.
Note: GeForce NOW Ultimate memberships are not available in all data centers. Please check the Service status website for more details.
We recommend a USB gaming mouse for PC and Mac. Logitech and Razer offer many different options. If you are using a mouse and experiencing stutters, you can try lowering your mouse polling rate (125Hz) to eliminate stutters.
Ultimate Members can enjoy up to 3840x2160, 3840x1600, 3440x1440, 2560x1440 and 2560x1600 resolutions. 120 FPS streaming will require a monitor that supports at least 120Hz, such as NVIDIA G-Sync Monitors. 240 FPS streaming will require a monitor that supports at least 240Hz. You must connect to the monitor using USB-C with DisplayPort/Thunderbolt, HDMI, DisplayPort, or Mini DisplayPort. Your system may require an additional adapter, or cable, to connect to the monitor. Any adapter used must support DisplayPort 1.2 or HDMI 1.4 for 1080p, or HDMI 2.0 for 1440p/4K. Please read this knowledge base article for more information.
Most GPUs released since 2015 can support up to 3840x2160/3840x1600 120 FPS and 1440/1600 120 FPS streaming. For more information on GPUs and specific resolutions, please read this knowledge base article for more information.
Ovo su preporucene konfiguracije sa sajta.
Windows PC
A 64-bit version of Windows 7, or newer, is required. We recommend using the latest version of Windows 10 Anniversary update. We do not support 32-bit versions of Windows.Internet Requirements
GeForce NOW requires at least 15Mbps for 720p at 60 FPS and 25Mbps for 1080p at 60 FPS. We also require less than 80ms latency from an NVIDIA data center. However, for the best experience, we recommend less than 40ms. Please read this knowledge base article on how to test your network.Recommended for GeForce NOW Ultimate Membership
Keyboards And Mice
Most built-in or USB keyboards work fine.We recommend a USB gaming mouse for PC and Mac. Logitech and Razer offer many different options. If you are using a mouse and experiencing stutters, you can try lowering your mouse polling rate (125Hz) to eliminate stutters.
Monitors
Most monitors work fine for all membership types. To unlock HDR benefits with the Ultimate membership tier, you must use a monitor that supports the HDR10 format.Recommended for GeForce NOW Ultimate Membership
Gamepads
- NVIDIA SHIELD controller connected wirelessly or using wired USB
- All Microsoft Xbox Wireless controllers using Xbox Wireless Adapter, Bluetooth, or USB
- Microsoft Xbox 360 connected wireless using a USB adapter or USB
- Sony PS5 DualSense connected using Bluetooth or USB
- Sony DualShock 4 connected using Bluetooth or USB
- Logitech Gamepad F310/F510/F710
- Note: you must set the controller to work in (Direct input mode)
- Note: the nano-receiver must be connected to a USB port that delivers enough power, such as a powered USB hub
- Steelseries Stratus+
- Steelseries Stratus Duo
- Razer Kishi V2
- Razer Wolverine
- Backbone One
- MOGA XP5-A Plus
PC Hardware Requirements
- Dual core x86-64 CPU with 2.0GHz or faster
- 4GB of system memory
- GPU that at least supports DirectX 11
- NVIDIA GeForce 600 series or newer
- If you are using a GTX 800m series, please read this knowledge base article
- AMD Radeon HD 3000 series or newer
- Intel HD Graphics 2000 series or newer
Audio Support
We support 2-channel stereo for Free Memberships. Priority memberships support stereo and 5.1 surround. GeForce NOW RTX 3080 memberships can support 2-channel stereo, 5.1 surround, and 7.1 surround.Ovo su preporucene konfiguracije sa sajta.
