Komp se jedva pali BlueSceen itd.
damirex
Cenjen
Kao prvo pozdrav :)
Imam sledeci problem kada mi je Racunar ugasen na primer 2/3h i probam da ga upalim moram nekoliko put da ga resetujem da bi digao sistem a problem je u tome sto mi se pojavljuje po nekad i famozni BlueScreen dok ga palim i kad posle nekoliko pokusaja uspem da ga upalim radi normalno sve, ne znam dali je do rama/napajanja ili sistema.
1.
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional information about the problem:
BCCode: 50
BCP1: FFFFF80082CDA2AC
BCP2: 0000000000000008
BCP3: FFFFF80082CDA2AC
BCP4: 0000000000000005
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\060311-17706-01.dmp
C:\Users\Damir\AppData\Local\Temp\WER-27362-0.sysdata.xml
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
2.
Windows
Problem: Shut down unexpectedly
060311-25568-01.dmp
sysdata.xml
WERInternalMetadata.xml
View a temporary copy of these files
Warning: If a virus or other security threat caused the problem, opening a copy of the files could harm your computer.
Koristim sledecu konfiguraciju>
Sistem: Microsoft Windows 7 Ultimate SP1
Procesor: AMD Phenom II X6 1055T, 2.8
Maticna: ASROCK MB - SOCKET AM3 - 890GX EXTREME4
Graficka: MSI AMD Radeon HD 6800
Ram Memorija: KINGSTON DDR3 HYPERX BLU 4GB (2X2GB) 1600MHZ CL9 - KHX1600C9AD3B1K2/4G X2 (8gb)
HD: DiST31000524AS ATA Device 1tb
Kuciste: LC POWER 7025B 600W-12 BLACK
Napajanje: LC POWER 600W LC600H-12 V2.31 12CM FAN
Ram memorija mi je trenutno stavljena na [AUTO] kao i Latency/Timing [AUTO]
kad testiram na "AVAREST" pise da ram radi na 1400mhz memori timings 9-9-9-24 cr2.
Ako neko zna na koliko treba da stavim ram 1600mhz timinge da radi normalno hvala.
Ljudi mi govore da mi je taj prob do Sistema,Rama ili cak napajanja pa ako neko zna da ga ne saljem za bg ako mogu sam da napravim ;)
Za početak testiraj memoriju preko Memtest+ (skini Hiren's boot CD, butuj ga i tamo ćeš ga naći).
Za napajanje jedino da probaš sa nekim drugim
Ako prodjes mem test, uradi i chkdsk - ta butovanja sa BSODom su garant napravila cudo i na disku.
To testira voltaže al ne može da testira pod opterećenjem.
Evo testirao sam sa Memtestom (ram mi je bio podesen AUTO u bios-u) samo neznam koliko dugo da cekam... ovde sam cekao oko 3h ako treba jos recite.
A ako je sve u redu sa ramom ostaje onda napajanje ili system verovatno.
Sry za flash on :)
    708.2 KB · Pregleda: 54
Sledece chkdsk a vrlo lako moze da se desi da je neki drajver - probaj da ga resetujes u safe modu sa minimalnim setom drajvera - ako se tu ne pojavi BSOD, gledao bih drajvere.
Ako nije to onda vidi za napajanje.
Skenirao sam C: pise da ima 0 gresaka, D nisam ni testirao jer sve verovatno ide na C drive, a jeli CHKDSK skenira i drivere posto su imale neke dve opcije obe sam selektovao /f/r/ nemam pojma vise ili je napajanje ili system probacu jos po nesto u svakom slucaju hvala.
Ako crkne napajanje nema veze ima garancija :p
p.s. na 1600mhz ddr3 ram koliko da stavim Timing ili samo auto?
Chkdsk ne proverava drajvere - probaj safe mode min konfig.
probaj nekoliko puta da dignes windows live imas ga hirens-u ako ne pravi probleme nikakve onda sigurno nije do komponenti (malo verovatno), moraces da reinstall windows, trebao si to odmah da probas pa da znas na cemu si :D
@laki71, kao sto ti BelThaZoR rece, ti testeri za napajanju su sra/nje, zato sto ne testiraju napajanje pod opterecenjem. Lako mogu da prijave da je napajanje Ok, a cim se ono malo optereti moze da popusti.
Kad ce ljudi da shvate da ploce Asrock ne treba da kupuju???mislim da je doslo do neslaganja ploce s ramom(tajmingsi ili nesto slicno)ili je ploca krenula da brljavi ko sto asrock obicno hoce.I drugo,kingston hiperx ram se ne slaze s nekim plocama,npr sa nekim MSI,provereno.Ako imas nekog da uzmes tudje ramove ,da zamenite na dan-dva bilo bi dobro,tek onda bi isao dalje,ka napajanju
Mani se testiranja s programima gubis vreme,zamena komponenti (ako je to moguce)je najtacniji test
Pa ni napajanje nije blago receno `prikladno` za tu masinu -> x6 phenom i ta grafulja (6850 ili 6870?) nisu mali potrosaci, a taj LC sigurno nema 600W (o tom se vec pripovedalo)
Ali ipak izgleda da nije do njega...
ne verujem da je napajanje.
BCCode: 50 je najcesce problem sa memorijom
probaj da izvadis onih 4GB rama i probaj samo sa 8 (probaj da izvadis sve stickove i ubadas jedan po jedan u masinu)
Moar da se ide redom, ako memtest prolazi... meni je to napajanje smesno za tu ringlu od procesora i graficku.......
