2.6 verzija je osakaćena za neke stvari u odnosu na 2.3 verziju, tako da tvoja konstatacija da je mnogo bolja ne stoji. Promenjen je malo raspored elemenata na ploči, koji je osnovni razlog zašto se manje greje, ima nešto drugačiji tjuner i to je to.
Original stuff in
http://www.dvbworks.com/happysat/modules.php?name=FAQ&myfaq=yes&id_cat=26&categories=SkyStar-2
SkyStar-2 Revision 2.3
Technical Specs SKYSTAR 2 :
Data broadcast via satellite for satellite TV and satellite Radio
no need of additional DVB-receiver
Receives digital databroadcast (e.g. Europeonline) up to 90 Mbps
Supports multiple satellites
Videotext
DISEqC 1.0, 1.1
Plug&Play
Input frequency 950 MHz-2150MHz
32 PID Filter simultanously
Multitransponder hopping
Supports MAC Mapping
Symbolrate 2-45 MS/sec.
SCPC and MCPC
Antenna F-Connector
no registration or subscription needed
System requirements: 128MB RAM, P3 min. 500Mhz , CD-ROM drive,
free and unused PCI-Bus Slot , 120MB harddisk space for full installation
Skystar-2 Revision 2.68
Difference:Boardtype 2.68
Components are the same as 'older' rev 2.3, only PCB layer was changed,
The ICs (B2C2) were placed somewhere else.
They enhanced the "Tuner-Cover" for better "cooling" of
that tuner (same type as rev2.3) but question remains if this
is really helpfull- IMHO TS could better place a fan like Gfx cards.
The info isn't totaly wright:
The version 2.68 dosn't auto detect symbol rates like the version 2.3 did
, bad news for the feedhunters , there's also minnor diferences in the way that it interacts with DiSEqC.
There's now a version 2.6C being sold in some online stores like http://www.dvbshop.tv
http://www.usa-x.org/1shop/images/ss2new.pdf
I don't now if the folowing picture is of the real 2.6C version because it's to much like the 2.68 or 2.6B
If you have more info just reply to this post .
