david
Koristim ove Logitech 4.1 zvucnike za kompjuter vec duzi niz godina ,ali sam sad u procesu prelaska na laptop varijantu pa bih prodavao ceo kompjuter.Razmisljao sam da zadrzavam ove zvucnike pa me interesuje da li je moguce sa tehnicke strane i koji bi mi av receiver preporucili za njih.Receiver bih povezivao sa lap topom i sa plazma televizorom( pretpostavljam preko hdmi veze).Kako sam pitanje postavio u delu foruma za audiofile,shvatam da je ovo daleko od nekog hifi sistema i verovatno ce mnogi smatrati kao skrnavljenje povezivanje ovih zvucnika na receiver,ali mi vrse posao za filmove i muziku . Molim vas dajte vase predloge....hvala
specifikacija :
· 400-RMS watts of awesome power for DVDs, music, and PC games
· 20 cm. diameter "long-throw" subwoofer with wood enclosure, delivers thunderous bass performance for the ultimate audio experience
· Ultra-wide bandwidth, phase-aligned satellite driver technology captures distortion-free tones across the full spectrum of sounds
· SoundTouch™ Control Centre with separate controls for volume, fader, and bass. Headphone socket included
· Patented M3D™ technology delivers realistic surround sound for intense gaming pleasure and fine quality music reproduction from standard two-channel stereo sound sources
· Home stereo style connectors use standard speaker wire so you can place the speakers anywhere you choose
· THX® certified
· Total power output: 400 watts RMS - Subwoofer: 188 watts RMS - Satellites: 212 watts RMS (4 x 53 W)
· Frequency response: 35 Hz - 20 kHz
· Signal-to-noise ratio: > 100 dB (A)
· Input impedance: 10,000 ohms
· Maximum SPL: 114 dB
· Satellites: high excursion, ultra-wide bandwidth driver with aluminium phase plug
· Subwoofer: large displacement 20 cm driver in solid wood enclosure
· Amplifier: true linear power amplifier with massive toroidal power supply
· Connectors: pro audio multi-junction speaker wire connectors, 3.5 mm headphone jack, front & rear channel inputs
specifikacija :
· THX® certified
