Klokovanje Interneta
bad
U ovom thread-u pisiti vasa savete za optimizaciju i poboljsavanje internet konekcije.
Tips and tricks.
Sve sto ste proverili! i pomaze pri brzem radu neta.
Hvala
Djole
Ovaj programčić sigurno radi. Ukoliko si advanced možeš i pored automatic sam da tweak-uješ parametre.
TCP Optimizer
Description: The TCP Optimizer is a free, easy Windows program that provides an intuitive interface for tuning and optimizing your Internet connection. Just download and run, there is no installaion required. The program makes it easy to find the best MTU and RWIN values, test latency and tweak all the important broadband related registry parameters. The Optimizer can be helpful with tuning any Internet connection type, from dialup to Gigabit+ :) If you need help with the program, check the TCP Optimizer documentation, read our broadband tweaking articles, the Optimizer FAQ, and/or visit our Forums. As an alternative, you can try one of our generic Registry patches instead.
http://www.speedguide.net/downloads.php
Skinuo sam ovo sa neta i radi :
Da bi se stranice brze ucitavale:
Idi na Start zatim Run pa ukucaj regedit, poslije toga:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetServicesTcpipServiceProvider
Sa desne strane klikni desnim dugmetom misa na svaku stavku navedenu ispod, biraj modify i promjeni slijedece vrijednosti:
Class = 1
DnsPriority = 1
HostsPriority = 1
LocalPriority = 1
NetbtPriority = 1
Sve vrijednosti treba da ostanu HEXIDECIMAL, prema tome, ne mijenjaj!
Restartuj kompjuter i to je to.
(Hvala Vibi!)
I
Ovo je vrlo prost zahvat na registru, a kod mene je (narocito na
Win XP) doveo do ogromnog povecanja brzine surfovanja sa IE6.
Važi za sve Windowse 95/98/ME i NT4/2000,XP sisteme sa instaliranim MS
Internet Explorerom 4/5/6.
Ovim se u stvari uklanja bug u MS Windows OS-ovima zbog koga dolazi do
skeniranja deljenih (shared ili remote) foldera/fajlova preko mreže za
Scheduled Tasks, i može ubaciti usporenje od cak 30 sekundi (!), jer
koristi dodatno vreme da pretraži udaljen(e) kompjuter(e).
Otvorite Regedit (Win95/98/ME) ili Regedt32 (WinNT4/2000/XP) i pronadite
sledeci kljuc:
HKEY_LOCAL_MACHINESoftwareMicrosoftWindowsCurrentVersionExplorerRem
oteComputerNameSpace
Oznacite (highlight-ujte) sledecu vrednost
{D6277990-4C6A-11CF-8D87-00AA0060F5BF}
i obrišite je: desni klik na nju -> izaberite Delete (taster DEL,
nalazi se
iznad tastera Insert)
Ova promena u registry-ju odmah stupa na snagu. Startujte IE i
prikljucite se na net, trebalo bi da odmah vidite razliku.
Jel sve to sto si naveo vazi samo ako se koristi IE?
Neki software za clock cable-modema ......Da li ti programi stvarno clockuju ili .......???
djstole je napisao(la):
Zar ne mislis, da zaista postoji takav softver, da ga ne bi vec koristio svaki cyber Srbin :D
Probaj da nadjes onspeed program bilo je reci o njemu i radi ok takodje imas i cfos i on daje dobre rezultate .
Probajte ovo
trebalo bi da ubrza net 20% :d :type:
