Kupicu neke stvarcice za novu godinu,pa rekoh da ujedno uzmem i mp3 player za kola ujedno kad vec uzimam na rate...Tamo gde uzimam nemaju bas neki veliki izbor mahom Kenwood i poneki Sony model.
Ono sto mi se svidelo je Kenwood KDC-W312AY koji kosta 7.000dinara a ovo su mu specifikacije:
# CD/MP3 PLAYER with AUXILLARY INPUT FOR iPOD OR PORTABLE MP3 DEVICE
# Full Detachable Faceplate
# 14 Segment Fluorescent (FL) Tube Display
# 50W x 4, Max Output Power
# System Q (Preset Sound Control)
# MP3/WMA Decoder Built-in
# Russian Character Display
# General Features
# DIN Size 1 DIN
# Detachable Faceplate
# Protection Case For Faceplate
# Angle Adjustment
# Rotary Encoder & Control Knob
# Operation mode 4-Directions + Push
# Attenuator with Smooth Volume Return
# Touch Sensor Tone
# IR Remote control capability (Optional)
# Digital Clock (24H)
# All-off Select (20/40/60 minutes)
# ISO connector included
# Display Features
# Display Type Fluorescent (FL) Tube Display
# Display Layout 14 segments x 8 Characters
# Dimmer Control 2 steps - Manual
# Demo Mode
# Special Character Display Russian Characters
# Tuner Features
# RDS (PI, PS, AF, TI, Clock)
# Radio Text (RDS)
# Programme Type Function (PTY)
# Enhanced Other Networks Function (EON)
# K3I - Clean Reception Tuner
# FM Reception
# AM (MW/LW) Reception
# Presets 24 Presets (18FM / 3LW / 3MW)
# Automatic Memory Entry (AME)
# Up/Down Seek Tuning
# Tuning mode (Auto1 / Auto2 / Manual)
# FM Stereo / Mono Selector
# CD Features
# CD-R/RW Compatible
# MP3 Playback with ID3 Tag Display
# WMA (Windows Media Audio) Playback
# Multi-session Disc Playback
# CD Text Support
# Supreme
# Digital Audio Converter 24 bit (built-in)
# 0 bit Mute
# Random Function (Track/Disc)
# Repeat Function (Track/Disc)
# Scan Function (Track/Disc)
# Audio Features
# Maximum Output Power 50W x 4
# Auxiliary input: Yes, on front panel
# Auxiliary Type: Mini-jack Built-in
# Pre-out 1 RCA (for external amp)
# Pre-out Output Level 2V
# Preout Rear / Subwoofer Switchable
# Subwoofer Reference Level Adj.
# Source Tone Control & Memory Bass / Mid / Treble
# Balance/Fader/Loudness Control
# Att.(-20dB) with smooth Volume Return
# System Q_SP (Preset Sound Control)
# Bass Boost Circuit
# Low-pass Filter
# Connectivity
# 2-way Telephone Mute Wire
# Cosmetics features
# Front/edge Silver
# Volume & operation knob or wheel Bright Silver
# Preset key finish Black Injection
# Escution Black Injection
# Key illumination Red
# Volume & operation knob illumination Red
# Triangle Illumination Red
Sad ono sto me zanima je a nigde nisam nasao da li ovaj model ima MOSFET pojacalo? Inace bio sam zagrejan da uzmem neki Pioneer-ov model recimo 2900 koji je nesto jeftiniji i ima MOSFET i vidim da ga dosta ljudi fura. Ali ovi tamo ne drze Pioneer, ima samo Sony, LG i Panasonic koji nisu bili zanimljivi.
Kakva iskustva imate sa Kenwood player-ima,cini mi se da mi je neko skrenuo paznju da Kenwood ima uzasan tjuner da lose hvata stanice za razliku od Pioneera i da mu je to najveca mana? Da li je jos neko imao takva iskustva?
Pored ovog Kenwood-a interesantni su mi bili Sony CDX-GT20-6.000din i Sony CDX-GT210-7.100din, e sad cenim da je Kenwood ipak bolji izbor od Sony-a ali ako Kenwood ima znatno losiji FM tjuner i od Sony-a onda...
P.S. Posto imam fabricki neki Aura (na Seat-u ) kasetofon,prilikom vadjenja je l treba mozda neki sraf sa strane da odvijem ili tako nesto ili samo da ga izvucem? I da raspored zica koje idu u postojeci kasetofon je isti kao na buducem CD playeru ili moze da varira pa moram da vidim u uputstvu CD playera ?
# General Features
# DIN Size 1 DIN
# Angle Adjustment
# Touch Sensor Tone
# Display Features
# Demo Mode
# Tuner Features
# Radio Text (RDS)
# FM Reception
# CD Features
# CD Text Support
# Supreme
# 0 bit Mute
# Audio Features
# Low-pass Filter
# Connectivity
# Front/edge Silver
