Ne uspeva mi da narežem DVD od 8gb gornjim rezačem, pritom nije u pitanju veliki ISO nego nekoliko normalnih fajlova. Disc at once failed, illegal disc, bla bla.
Nero izbaci sledeći log:
Windows XP 5.2
AMD64
Wow64Process
WinAspi: -
NT-SPTI used
Nero Version: 9.2.6.100
Internal Version: 9, 2, 6, 100
Recorder: <_NEC DVD_RW ND-4571A> Version: 1-01 - HA 1 TA 0 - 9.2.6.100
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data
CD-ROM: <_NEC DVD_RW ND-4571A >Version: 1-01 - HA 1 TA 0 - 9.2.6.100
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 6Y080L0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : _NEC DVD_RW ND-4571A atapi Port 0 ID 1 DMA: On
DiskPeripheral : ST31000340AS atapi Port 1 ID 0 DMA: On
DiskPeripheral : WDC WD3200JS-55PDB0 atapi Port 2 ID 0 DMA: On
=== CDRom-Device-Map ===
_NEC DVD_RW ND-4571A F: CdRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 4094MB (4192464kB)
Free physical memory: 3043MB (3116032kB)
Memory in use : 25 %
Uncached PFiles: 0x0
Global Bus Type: default (0)
Check supported media : Disabled (0)
25.3.2010
UDF compilation
8:29:06 PM #1 Text 0 File SCSIPTICommands.cpp, Line 452
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
8:29:07 PM #2 Text 0 File Isodoc.cpp, Line 6940
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : pure
UDF Options : manual
UDF Revision : 1.02
UDF Partition Type : physical
8:29:07 PM #3 Text 0 File Burncd.cpp, Line 3587
Turn on Disc-At-Once, using DVD media
8:29:07 PM #4 Text 0 File DlgWaitCD.cpp, Line 313
Total disc capacity: 4171712 8147MB
User data to be written: 2828368 5524MB
Free space on disc: 4171712 8147MB
8:29:07 PM #5 Text 0 File DlgWaitCD.cpp, Line 325
Write in overburning mode: NO (enabled: CD)
8:29:07 PM #6 Text 0 File DlgWaitCD.cpp, Line 2882
Recorder: _NEC DVD_RW ND-4571A, Media type: DVD-R Dual Layer
Disc Manufacturer ID: <CMC MA> <G. AD8>
Disc Application Code: 2, Disc Physical Code: 145
8:29:07 PM #7 Text 0 File DlgWaitCD.cpp, Line 500
>>> Protocol of DlgWaitCD activities: <<<
8:29:07 PM #8 Text 0 File ThreadedTransferInterface.cpp, Line 744
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2828368 (2828368) = #2828368/628:31.43
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2828368 blocks [F: _NEC DVD_RW ND-4571A]
8:29:07 PM #9 Text 0 File ThreadedTransferInterface.cpp, Line 946
Prepare [F: _NEC DVD_RW ND-4571A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 5792497664, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 2828368 | 0 | 0x00
2828368 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
8:29:07 PM #10 Text 0 File SCSIPTICommands.cpp, Line 242
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
8:29:07 PM #11 Text 0 File Burncd.cpp, Line 4320
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
8:29:07 PM #12 Phase 24 File dlgbrnst.cpp, Line 1767
Caching of files started
8:29:07 PM #13 Text 0 File Burncd.cpp, Line 4442
Cache writing successful.
8:29:07 PM #14 Phase 25 File dlgbrnst.cpp, Line 1767
Caching of files completed
8:29:07 PM #15 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 8x (11,080 KB/s)
8:29:07 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2676
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
8:29:07 PM #17 Text 0 File DVDPlusDualLayer.cpp, Line 1883
GetDriveCaps: LAST LBA of layer 1 is 0
8:29:07 PM #18 Text 0 File DVDPlusDualLayer.cpp, Line 1424
SetDriveCaps: Set LAST LBA of layer 1 to 1414191
8:29:07 PM #19 Text 0 File DVDPlusDualLayer.cpp, Line 1883
GetDriveCaps: LAST LBA of layer 1 is 1414191
8:29:07 PM #20 Text 0 File DVDPlusDualLayer.cpp, Line 592
Disc finalized, LBA total Image size: 2828368 (5524MB), Last LBA L0: 1414191 (2762MB)
8:29:07 PM #21 Text 0 File DVDPlusDualLayer.cpp, Line 768
L0 Data Zone Capacity not set.
Max LBA L0 2092895 (1FEF5Fh, 4087MB), next writable address 0 (0h, 0MB)
8:29:07 PM #22 CDR -1205 File DVDPlusDualLayer.cpp, Line 784
Burning Layer 1
8:29:07 PM #23 Text 0 File DVDPlusDualLayer.cpp, Line 794
Start writing layer 1 at address 0 (0h)
Recording mode: unknown Recording Mode
8:29:07 PM #24 Text 0 File DVDR.cpp, Line 3279
Recording mode: Sequential Recording Mode
8:29:07 PM #25 Text 0 File DVDR.cpp, Line 3433
Start write address at LBA 0
DVD high compatibility mode: Yes
8:29:07 PM #26 Text 0 File Cdrdrv.cpp, Line 9966
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.1x (6), Extended Part Version: 3.0 (48)
Disc Size: 120 mm, Maximum Transfer Rate: <not specified> (F h)
Number of Layers: 2, Track Path: Opposite Track Path (OTP), Layer Type: recordable
Linear Density: 0,293 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: FCC8FF h
End Physical Sector Number in Layer 0: 22EF5F h (LBN: 1FEF5F h, 4087 MB)
Data in Burst Cutting Area (BCA) does not exist
Revision number of maximum recording speed: 3.0
Revision number of minimum recording speed: -
Revision number table of recording speed: 1.0 2.0 - - - - -
Class: 0, Extended part version: 48
Start PSN of the Extra Border Zone: 2FE10 h
Start PSN of Physical format information blocks in Extra Border Zone: 2FFA0 h
Media Specific [16..783]:
00 30 00 10 20 00 00 00 - 00 00 00 30 00 00 00 00 .0.........0....
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
8:29:07 PM #27 SPTI -1046 File SCSIPassThrough.cpp, Line 215
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1046)
CDB Data: 0x53 00 00 00 00 00 2B 28 50 00 00 00
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x30
Sense Qual: 0x05
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 30 05
8:29:07 PM #28 Text 0 File DVDR.cpp, Line 3571
Reserved Track size: 2828368 (2B2850h, 5524MB) -> return code -1046
8:29:07 PM #29 CDR -1046 File ThreadedTransferInterface.cpp, Line 1680
Illegal disc
8:29:07 PM #30 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1680
Could not perform start of Disc-at-once
8:29:07 PM #31 Text 0 File DVDPlusDualLayer.cpp, Line 1424
SetDriveCaps: Set LAST LBA of layer 1 to 0
8:29:07 PM #32 Text 0 File ThreadedTransfer.cpp, Line 273
Pipe memory size 83836800
8:29:07 PM #33 Phase 38 File dlgbrnst.cpp, Line 1767
Burn process failed at 8x (11,080 KB/s)
8:29:07 PM #34 Text 0 File SCSIPTICommands.cpp, Line 289
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
8:29:10 PM #35 Text 0 File Cdrdrv.cpp, Line 11243
DriveLocker: UnLockVolume completed
8:29:10 PM #36 Text 0 File SCSIPTICommands.cpp, Line 452
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
Windows XP 5.2
AMD64
Wow64Process
WinAspi: -
NT-SPTI used
AutoRun : 1
Excluded drive IDs:
BUFE : 0
25.3.2010
UDF compilation
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
UDF Mode : pure
UDF Revision : 1.02
DAO infos:
MCN: ""
DAO layout:
Burning Layer 1
Sense Code: 0x30
Sense Qual: 0x05
Illegal disc
Existing drivers:
Registry Keys:
