Evo da i ja pitam nešto što nema u tim temama čije si linkove koristio...
Mene interesuje neki freeware program koji radi taj posao... Konkretno, našao sam ih nekoliko, a ubedljivo najmanji je "Fundelete" (ispod megabajta, što je spas za moj dial-up)...
E sad, u opisu mogućnosti piše mu:
Fundelete replaces the standard Windows NT/2000/XP recycle bin and allows you to undelete files, even if they have been deleted from other programs or the command line. The standard recycle bin only catches files that have been deleted from within Windows explorer - Fundelete extends this to include all files, regardless from where they have been deleted. You can set an exclusion list for files that you do not want to be kept in the Fundelete recycle bin (e.g your browser cache, cookies, temp files etc.) and also remove all or selected files from the bin. Fundelete cannot recover files that have been deleted before it was installed. The program was originally designed for Windows NT, but works with 2000 and XP as well.
Znači li to da taj program obrisane fajlove čuva u svojoj korpi za otpatke, odnosno, nisu stvarno obrisani? To mu onda i nije neki štos jer bi mi se hard lagano punio svim i svačim, pre nego što mi program stvarno zatreba da spase nešto...
Kako uopšte rade ti programi? Svi ostali su minimum 6-7 MB, a jedan već imam - PC Inspector Recovery (za memorijske kartice, dobio uz čitač). Postoji i verzija za komp... Da li je pametnije da ipak nju skinem, umesto ovog "Fundelete"?
U svakom slučaju, nameravam da instaliram jedan takav program (zlu ne trebalo), da ga ne moram instalirati u trenutku kada mi zatreba, pa da tako njime "prepišem" preko obrisanih podataka...
