[FAQ na jabber.nu:]
Stucked at 40%
If you are using http connection and get stucked at 40% with the error "Can't connect to server" it might be because you are using a wap connection. Download setting from you operator for a "internet connection" this should fix the problem.
Kako da podesim "internet connection" na 063
Ja se kacim na profil APN internet User mobtel pass gprs
i radi mi i http, da li ima jos neki brzzi profil od mobtela ?
http podesen u IMIC klijentu
tel. z1010
Stucked at 40%
tel. z1010
