Iskljucivanje kamere nakon updatea Skypa
Dark Angel
CPU & Cooler
XEON E5440 mod 775
Matična ploča
ASUS P5B
RAM
6 Gb
GPU
GIGABYTE 1050 TI
Storage
SSD Biostar 240Gb + HDD...
Zvuk
XONAR D 2
PSU
CORSAIR
Monitor
SAMSUNG 32" TV
Miš & tastatura
LOGITECH MX MASTER x2
Ostale periferije
LOGITECH Z-5500
Laptop
ASUS VIVOBOOK OLED 1513, MACBOOK PRO 5.2 + 7.1 + ...
Tablet
ASUS TRANSFORMER
Pristup internetu
  1. Optički internet
Nakon apdejta skajpa isti ima stalno ukljucenu kameru, u opcijama vise ne postoji ( bar ja ne vidim da ima ) opcija za iskljucivanje kamere
Moze li se ovo resiti ?
Desktop Skype ide u istoriju, ostaje samo APP u W10 i W8.
^ Kad to?
https://support.skype.com/en/faq/fa10328/what-are-the-system-requirements-for-skype
Skype for Windows Desktop
Version
Windows 10
Windows 8.1
Windows 8
Windows 7 (32-bit and 64 bit versions supported) - see note below
Windows Vista
Windows XP SP3 (32-bit and 64 bit versions supported) - see note below
Note: Skype (version 8) on Windows Desktop requires:
Windows 10 Version 1507, or version 1511
Windows 8.1
Windows 8
Processor
At least 1 GHz
RAM
At least 512 MB
Additional software
DirectX v9.0 or higher
Notes:
If you're using Windows 7 (SP1), upgrade your Internet Explorer to v11.
If you're using Windows XP SP3, make sure you're using Internet Explorer 8 or higher.
While the desktop and mobile versions of Skype classic are not being killed off to the point that they will be unusable, after November 1 and 15 respectively, they will not longer be supported, and will no longer receive updates.
Znaci bice otprilike kao Windows XP - i dalje moze da se koristi, ali nema mnogo smisla.
Možda srede APP sada kada o ovome ne treba da se brinu.
Trenutna verzija klasika meni prihvatljivo radi. Neka ostave ovako. Apdejtovi mi ne trebaju :)
