IrfanView 4.36
Kritika
Nova verzija jednog od najboljih programa za pregled (sa najosnovnijom obradom) fotografija na Windows OS
www.irfanview.com/
- New Lossless JPG Dialog option: Rebuild EXIF-Thumbnail
- Update of EXIF-Thumbnail on JPG-Lossless-Crop
- Option to Edit EXIF date/time (Options menu or Thumbnails window for batch mode)
- Improved color accuracy in "Decrease color depth" function
- Added "Best quality" option in "Decrease color depth" dialog (Thanks to Kornel Lesinski!)
- New (Freeware) PlugIn for DWG format - thanks to BabaCAD-Software guys!
- New feature: Replace Color (Image menu and Advanced Batch dialog)
- New feature: Create tiled image (Image menu)
- New PlugIn: Filter Sandbox (Image->Effects menu, JewelScript, thanks to Stefan Kuhn!)
- Option to invert single color channels only (Image menu)
- New Edit menu option: Show Grid (see also Properties->Editing for cell size)
- New Slideshow Burning PlugIn for WinXP SP3 or later (Thanks to Eric Haddan!)
- New display options added: Fit small image side to window/desktop
- Profiles option added to Batch Rename dialog
- New Advanced Batch dialog option: Set new image size in MegaPixels
- New options for Fine Rotation effect: Keep old image size and background
- New feature in Color Corrections dialog: Change White Balance
- New effect in "Image->Add border/frame" dialog: Inside fading frame
- New Thumbnails menu: Extract pages from selected multipage files
- New Add Text dialog effect: Filled outline text (Thanks to Wong Shao Voon)
- Negative and Grayscale menus can work on selections
- Improved selection handling with large zooms
- Updated Icons-Plugin (bigger/nicer icons, thanks to Florian Kilzer)
- New hotkeys: CTRL + SHIFT + left/right arrow: Fine rotation, 0.10 deg
- New hotkeys: CTRL + SHIFT + up/down arrow: Fine rotation, 0.05 deg
- Batch-Scan dialog: some placeholders can be used for the filename (help file)
- New text placeholders to add $ and | characters (see help file)
- New (admin) INI file option: Set save formats in Save-As dialog (see FAQs)
- New hotkey for slideshow mode: SHIFT + Z = show all or portrait/landscape images
- Hotkey: G = stop or resume GIF/ANI animation (browse frames/pages if stopped)
- DCX/ANI loading bug fixed (reported by FuzzMyApp, thanks!)
- FPX bug fixed (reported by Secunia/Krystian Kloskowski, thanks!)
- Added reading support for 32-bit (96 BPP) TIF images
- New command line option: /multipdf (same syntax as /multitif)
- Several PlugIns are changed/updated,
