slatkisi
Imam jedan veliki problem..
Pre par dana sam instalirao XP zajedno, nakon toga i SP3.
Danas sam ubacivao programa, i sada kada sam instalirao Google side bar ne mogu da ga pokrenem jer dobijam sledecu gresku:
"The system DLL user32.dll was relocated in memory. The apliction will not run properly. The relocation occured becouse the DLL c:\WINDOWS\system32\SHALL32.dll occupied an address range reserved for Windows system DLLs. The vendor supplyung the DLL should be contacted for a new DLL"
Sta da radiom kako bih mogao bez problema pokretati sve aplikacije?
