HTC MTeoR, Qtek 8500, Qtek 8310 GPRS MMS WAP podešavanja – uputstvo u 13 koraka
msav
Evo kako izgledaju definitivna Mobtel/Telenor 063 podešavanja za gornje modele (kao i ostale sa WM5). Nakon unosa, bez problema radi GPRS, MMS, WAP. Za MTS analogno, samo promenite podatke cheers
Dakle:
1) Start/Settings/Connections/GPRS
2) obrisati sve stavke
3) Menu/Add
– Mobtel GPRS
– Connects to: The Internet
– Access point: internet
– username: mobtel
– password: gprs
– Primary DNS: 0.0.0.0
– Secondary DNS: 0.0.0.0
– IP Adress: _prazno_
4) Done
5) Menu/Add
– Mobtel MMS
– Conects to: The Internet
– Access point: mms
– username: _prazno_
– password: _prazno_
6) Start/Settings/Connections/Proxy
7) Menu/Add
– Mobtel WAP GRPS
– Connects from: The Internet
– Connects to: WAP Network
– Proxy: 217.065.192.033:9201
– Type: WAP
8) Start/Messaging
9) MMS/Select
10) Menu/Options/Account Options/MMS
11) uključiti sve sem: reject all messages
– No of Attempts: 3
– Photo Resolution: Original
12) Menu/MMSC Settings
13) obisati sve stavke i kreirati novu Menu/New
– Mobtel MMS
– MMSC URL: http://mms.mobtel.co.yu/servlets/mms
– WAP Gateway: 217.065.193.033
– Port: 8080
– Connect Via: WAP Network
– Max Sending Size: 200K
– WAP Version: 2.0
znas mozda i za MTS mrezu parametre i podesavanja za Qtek?
Treba promeniti sledeće korake:
– username: mobtel
– password: gprs
– Access point: mms
Mislim da čak i ovde na benchu ima ovih podataka (u uputstvima za podešavanje drugih telefona). Ako ne nađeš, zovi 789 i pitaj ih.
Ovo je uputstvo koje sam dobio iz Telenora. Ipak jos uvek nisam naterao Qtek 8310 da radi. Na primer ne mogu da nadjem WAP Gateway kod mene.
GPRS
1. Start
2. Settings
3. More – Connection - GPRS
4. Menu – Add (u desnom donjem uglu)
5. Connects to: WAP Gateway
6. Access point: internet
7. User name: telenor
8. Password: gprs
9. Primary DNS: ostaviti prazno
10. Secondary DNS: ostaviti prazno
11. IP address: ostaviti prazno
12. Birate Done kako bi profil ostao sačuvan i vraćate se jedan korak nazad.
13. More (poslednja opcija na listi)
14. Proxy
15. Menu – New (ili Add) – u donjem desnom uglu
16. Connects from – WAP Gateway (bira pozicioniranjem na strelice i kretanjem levo ili desno)
17. Connects to: WAP network (bira pozicioniranjem na strelice i kretanjem levo ili desno)
18. Proxy:217.065.192.033:8080
19. Type: HTTP
20. User name: ostaviti prazno
21. Password: ostaviti prazno
MMS
22. Start
23. Settings
24. More – Connection - GPRS
25. Menu – Add (u desnom donjem uglu)
26. Connects to: WAP Gateway
27. Access point: mms
28. User name: ostaviti prazno
29. Password: ostaviti prazno
30. Primary DNS: ostaviti prazno
31. Secondary DNS: ostaviti prazno
32. IP address: ostaviti prazno
33. Birate Done kako bi profil ostao sačuvan i vraćate se jedan korak nazad.
34. More (poslednja opcija na listi)
35. Proxy
36. Menu – New (ili Add) – u donjem desnom uglu
37. Connects from – WAP Gateway (bira pozicioniranjem na strelice i kretanjem levo ili desno)
38. Connects to: WAP network (bira pozicioniranjem na strelice i kretanjem levo ili desno)
39. Proxy:217.065.192.033:8080
40. Type: HTTP
41. User name: ostaviti prazno
42. Password: ostaviti prazno
