HP LJ 1010: Unsupported personality:PCL
Genghis Khan
Shta god hocu da ishtampam na papiru se pojavi samo Unsupported personality: PCL
Vec sam ranije imao ovaj problem i nemam pojma kako sam ga reshio. Evo sada opet. Vidim na sajtu Hp-a gomile ljudi sa slichnim problemom ali nigde ne vidoh reshenje :(
Kod:
As stated in an earlier post:
The HP LaserJet 1010 and 1012 series printers are host based and do not support PCL printing. If a PCL driver is used with either of these printers, an error page will print with the words Unsupported Personality: PCL in the upper left hand corner.
Solution :
Install the host based driver for these printers only.
If PDF document printng continue to fail using a host based driver, another printer that supports PCL or PS is recommended.
Ostatak na http://www.tek-tips.com/viewthread.cfm?qid=789193 ili lupi na Googleu "Unsupported personality: PCL" Izaći će dosta toga :)
Izashlo je dosta toga i googlao sam ja podosta ali nijedno predlozeno reshenje mi nije reshilo problem.
