Vince Carter
http://flashman.rpc1.org/Firmware/P...VR-107Dv1.13-RPC-1+12xRip+nx4all_DVRFlash.zip
ili
http://pioneerdvd.rpc1.org/DVR-107D v1.13 - RPC-1 + 12xRip + nx4all.zip
Iz readme-a:
Kod:
Drive: Pioneer DVR-107 (Dual format 8x speed DVD+/- Burner)
Also known as: DVR-A07, DVR-107D, DVR-A07D, etc.
Firmware Rev.: v1.13
Author: >NIL:
Date: 2004.04.25 - 19:06 GMT
Patched: o RPC-1 (Region Free):
Remember, patching your drive to region free is only half
the job. A region free drive will not turn your system
region free by itself. For more info, please read
[url]http://forum.rpc1.org/viewtopic.php?t=239[/url]
o 12xRip (Unlimited ripping speed):
The official firmware from Pioneer limits the ripping
speed on video discs. This limitation has been removed.
12x is only the maximum THEORETICAL speed that the drive
can achieve, but not the sustained speed you are likely to
get when ripping. Most DVD's will start ripping around 2x
to 4x and end up around 8x or 10x. THIS is normal.
o nx4all : All speeds for (almost) all media!
This firmware allows you to select ALL burning speeds on
ALL media (except +RW). The official firmware from Pioneer
only allows a limited set of Pioneer approved media to use
these specific speeds but this patch removes that
limitation. It should NOT alter the write strategies for
approved media however.
PROPER BURN OF NON APPROVED MEDIA IS NOT GUARANTEED!
NOT patched: o 2.4x and 4x on +RW media
Release Notes: This firmware was used succesfully to burn PRINCO (4x) and
RITEKG04 (4x) DVD-R media at 6x and 8x speed. It was also
used to burn RICOH (4x) DVD+R at 8x. If you are not sure
whether the media you are using will burn properly at high
speed, please look for other users experience at
[url]http://forum.rpc1.org[/url]
AGAIN, HIGH SPEED BURN OF LOW GRADE MEDIA IS NOT GUARANTEED
Flashing Instructions: 1/ Download the latest version of DVRFlash from
[url]http://pioneerdvd.rpc1.org[/url] and extract the executable you
need (Windows, DOS or Linux) in the directory where you
extracted the patched firmwares
2/ READ THE DVRFLASH INSTRUCTIONS!!!
3/ If you are flashing from windows, and I: is your DVR-107
drive, open a DOS window and type a command like:
DVRFlash -v I: R7100107.113
or, *IF* you need to flash the kernel (Rebadged -> Pioneer):
DVRFlash -vf I: R7100007.113 R7100107.113
Useful Links: [url]http://forum.rpc1.org/[/url] (DVD-R/RAM/+RW section)
[url]http://pioneerdvd.rpc1.org/[/url]
