histle.org :mad:
sebekkg
CPU & Cooler
I5 6600k, cm hyper 212
Matična ploča
Z170 hd3
RAM
16gb ddr3
GPU
Msi 1060 6GB
Storage
20 TB
Zvuk
On board
PSU
Tt 730
Kućište
Nzxt
Monitor
2x hp 24
Miš & tastatura
Logitech g710+, mx master 3
Laptop
Elitebook
Kao i vecina vas imam precicu za odlazak na fb, i desava se u poslednje vreme, malo malo pa mi umesto facebook-a, vrsi premoscavanje i zavrsim na ovom sajtu hisle.org
Jesam li zayebao nesto, ili se jos nekom desava. najradije bih blokirao ovu stranicu ili procistio komp mozda. ne znam sta mi je ciniti :mad:
    117.5 KB · Pregleda: 122
Verovatno si kliktao tamo gde nisi trebao.
Proveri hosts fajl (windows\system32\etc\drivers\) i/ili proteraj Malwarebytes.
ja sam probao da ga blokiram i napisao sam ovo u host fajlu
# Copyright (c) 1993-2009 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
# localhost name resolution is handled within DNS itself.
# 127.0.0.1 localhost
# ::1 localhost
# 127.0.0.1 www.histle.org
# 127.0.0.1 histle.org
Skloni tarabe, mora da bude ovako:
Kod:
# space.
# For example:
#	::1 localhost
	127.0.0.1	[url]www.histle.org[/url]
**Edit
Proveri pluginove u chromeu, mozda je instaliran neki koji ne bi smeo da bude instaliran :)
^ Time si localhost preusmerio na taj histle.org i nisi ništa uradio. Ako u hosts-u nema ništa za Facebook onda ne treba da se menja.
+1 Obriši to što si dopisivao, nije tu problem. Probaj sa drugim browserom.
od plugin-ova u chromu imam:
Adobe Flash Player (2 files) - Version: 11.7.700.203
Chrome Remote Desktop Viewer
Microsoft Office (2 files) - Version: 14.0.4730.1010
Native Client
Chrome PDF Viewer
Google Update - Version: 1.3.21.145
Kaspersky Anti-Virus - Version: 13.0.1.4190
Adobe Reader - Version: 11.0.03.37
Java(TM) (2 files) - Version: 10.21.2.11
Silverlight - Version: 5.1.20125.0
Adobe Shockwave Player - Version: 12.0.2r122
A od ekstenzija? Nesto tipa "Facebook ad blocker"?
imam to. evo izbacio sam sad. videcu da li ce biti bolje. posto se desi da nemam po ceo dan taj ispad, pa onda dva kilka zaredom na fb on izbacuje njega, a na treci opet fb.
127.0.0.1 histle.org [/code]
Tačno
O čemu vi to pričate? Kakvo preusmeravanje localhost na pomenuti sajt?!
Kao prvo taraba ispred poništava dejstvo i najčešće se koristi da se da pojašnjenje a kao drugo nemože se localhost preusmeriti na neki sajt već se određeni hostovi preusmeravaju na localhost tako da računar umesto da vidi te sajtove vidi svoj local host 127.0.0.0 ili pak 0.0.0.0. u zavisnosti od OS i kako je podešeno
Ali mu to svejedno neće rešiti problem. Što je on stavio localhost adresu za histle.org neće sprečiti korumpirani browser da odradi redirekciju. Jedino bi eto umesto te stranice mogao da dobije error 404 u slučaju da redirekcija ne vodi direktno na IP adresu, već zahteva DNS rezoluciju.
Browser je inficiran Facebook Adblock ekstenzijom. Makni je i rešen problem.
izbacio sam ono g*vno od facebook blocker-a i za sada nemam tih problema. nadam se da će biti sve ok. ko je mogao da posumnja da će to biti problem.
Da, s'tim što je redosled obrnut. Prvo ide stavka šta se redirektuje, a onda na šta se redirektuje. Sa ta dva reda je on 127.0.0.1 redirektovao na histle.org što nema veze ni sa čim.
Mislim da grešiš, na IP adresu se redirektuje url koji kucaš u browseru.
Ja sam se složio sa drugom rečenicom, da ne treba da čačka hosts ako ne postoji neki loš upis u njemu.
Unosom adrese u browser, taj unos u hosts fajlu preusmerava na 127.0.0.1 i time blokira pristup navedenom sajtu. Tako funkcionise i blokiranje reklama kod Androida, a i pojedinih programa koji bi da proveravaju licencu kod Windowsa. :D
Ali nevažno, problem je bio do samog browsera i problem je rešen. :)
