HINO - pomoc pri izboru monitora
Bojan84
Treba mi pomoc prilikom odabira monitora sto hitnije, uzeo bih monitor velicine 23 odnosno 24 inch-a a izbor je ogranicen na sledece modele, cena je vise manje sllicna i ne igra vaznu ulogu, bitan mi je samo kvalitet, dakle izbor je:
1. BENQ 24" G2420HDB TFT Full HD 5ms
Rezolucija 1920x1080
Konektori D-Sub, DVI-D
Odziv 5ms, 2ms (GTG)
Kontrast 40000:1 (dinamički), 1000:1 (statički)
Osvetljaj 300cd/m^(2)
Osvežavanje 50 - 76 Hz
Veličina tačke 0.276mm
Dodaci Senseye+Photo
Napomena VESA wall mounting 100mm x 100mm
Garancija 36 meseci
2. Samsung 23.6" LED 1920x1080 LS24B150BL/E
Tip : TFT LED 59,94 cm Wide
Dijagonala : 24 " (Vidljiva dijagonala 23.6")
Rezolucija : 1920x1080 px FULL HD
Osvetljenje : 200 cd/m2
Kontrast dinamički : 5.000.000 :1 (mega contrast)
Vreme odziva : 5 ms
Ugao vidljivosti : 170/160 °
Ulaz DVI-D, 15pin D-Sub
Potrošnja energije : 30 W
Dimenzije: 569 x 416 x 197 mm; 3,6 kg
3. DELL 23" LED 1920x1080 dvi hdmi S2330MX
Panel Type: TN - Twisted Nematic, Non-glare
Max Preset Resolution: Full HD 1920 x 1080 @ 60Hz
Contrast Ratio: 1000 : 1 Static (typical), 8 Million:1 Dynamic (estimated)
Brightness: 250 cd/m2 (typical)
Response Time: 2ms typical overdrive (Gray to Gray)
Max Viewing Angle: (160° vertical / 170° horizontal)
Color Gamut: 82% (CIE 1976) / 72% (CIE 1931)
Color Support: 16.7 million colors
Pixel Pitch: 0.265 mm
Panel Backlight: LED
CONNECTIVITY: VGA, DVI-D (HDCP), Comes with DVI-HDMI dongle
4. ASUS 23" LED VS238H 1920x1080 DVI HDMI
Tip LED LCD
Rezolucija 1920x1080 Full HD
Osvežavanje 60 Hz
Velicina piksela 0.2655 mm
Osvetljenje 250 cd/m2
Kontrast 1000:1
Dinamicki kontrast 50,000,000:1
Vreme odziva 5 ms
Ugao vid. horizon. 170°
Ugao vid. vertikal. 160°
Zvucnici
HDMI, D-Sub, DVI-D, Audio In/Out
5. LG LED E2350T-PN 23" 5ms DVI Crni
Dijagonala: 23"
Vrsta monitora: LED
Vrsta panela: TN
Rezolucija: Full HD 1920x1080
Kontrast: 5M:1 ( pet miliona)
Brzina odziva: 5ms
Konekcije: D-Sub; DVI-D;
Odnos stranica: 16:9
Ugao gledanja: 170°/160°
Boja: klavir crna
Ergonomija: tilt;
Osvetljenost: 250 cd/m^(2)
6. LG 24" LED E2442T-BN 1920x1080 dvi Crni
Dijagonala ekrana 24" Wide
Maksimalna rezolucija 1920x1080(FullHD)
Osvetljenje 250cd/m2
Kontrast DC 5000000:1
Vreme odziva 5ms
Ugao vidljivosti 170/160
Povezivanje VGA D-Sub, DVI-D (sa HDCP-om)
i na kraju jedini IPS
LG 23" LED IPS234V-PN
Vrsta monitora IPS LED LCD monitor
Veličina (inča) 23
Vrsta ploče IPS
Osvetljenost 250cd/m2
Odnos kontrasta (DFC) 5000000:1
Vreme odziva 14ms
Ugao gledanja (CR?10) 178/178
Boje na ekranu 16.7M
Prodavac hvali Asus-a, meni se nekako najvise svidja samsung ili dell. U pitanju su osim poslednjeg monitori sa TN panelima i ipak bih izeo TN panel jer mislim da su IPS paneli jos uvek razvoju i cini mi se citajuci da dosta ima reklamacija. Generalno pitanje posto nisam imao prilike da uzivo vidim, koliko su IPS paneli kvalitetniji odnosno bolji od TN.
To sto se IPS tehnologija jos uvek razvija ni u kom slucaju ne znaci da TN paneli jos uvek imaju neke prednosti. "Problemi" IPS tehnologije uglavnom pogadjaju e-IPS, najjeftinije panele - koji su bez obzira na to debelo bolji od TN panela. Reklamacija svakako nema vise nego kod TN panela.
Ne moze teoretski odgovor da ti "objasni" koliko i kako su bolji, nije Pozarevac sigurno toliko mali da nemas gde da vidis IPS panel uzivo i da uporedis sa TN panelom. Prosto moras sam videti uzivo i videti da li je po tvom ukusu.
Ne mogu da verujem sta mi se desilo, uzmem ti ja ovaj Samsung, kao najlepsi po izgledu i rukovodio sam se subjektivnom utisku da je samsung ime medju monitorima (malo sam ispao iz tokova u it svetu) donesem kuci prikljucim i ono uzas. Ugao gledanja nije 170/160 vec 90/65 sto i pise na zvanicnom sajtu. Danas odmah ga vracam u radnju u trazim zamenu za ovaj LG LED IPS234V-PN, ipak sam odlucio da uzmem IPS posle dugog citanja opisa i komentara korisnika, koliko sam video vreme odziva za ovaj monitor nije 14ms nego 5ms sto potvrdjuju ljudi na raznim forumima cak se i na nekim zvanicnim non-english sajtovima LG-a navodi da je vreme odziva za ovaj monitor 5ms. I posle ovog iskustva sa uglom gledanja od 90/65 :D uzimam IPS ciji je ugao gledanja taleko bolji i od TN panela koji imaju i standardni ugao 170/160. Opekao sam se zestoko.
Strasno, bezite dalje od ovog Samsunga sto dalje. Ako budu pravili problema u radnji zovem trzisnu inspekciju jer na njihovom zvanicnom sajtu radnje u specifikaciji stoji da je ugao gledanja 170/160 cak je u opisu monitora u radnji stajalo da je ugao gledanja 170/160, cista obmana. Odstampao sam specifikaciju sa njihovog sajta i sa zvanicnog sajta samsunga i to nosim kod njih.
Vratio sam Samsung i uz malo rasprave uspeo da ga zamenim za LG IPS234V-PN. Sta reci kao da sam ponovo progledao, sada vise i ne pomisljam na monitore sa TN matricom, ovo je fenomenalno, kristalno cista slika sa neverovatno vernim prikazom boja, ugao gledanja odlican, sve naj naj. Jako sam zadovoljan, i da se zahvalim useru Jericho na savetu posto sam na pocetku imao dosta predrasuda prema monitorima sa IPS panelima, ali evo uverio sam se i dajem svakom savet da nemaju razloga da se dvoume izmedju TN i IPS panela, IPS bez dvoumljenja. Probao sam takodje par igara i nisam primetio tzv. ghosting efekat. Jos jednom sve preporuke za IPS panele.
