Hard disk ima lose blokove
No_LiMiT
Imam sljedeci problem: The device, \Device\Harddisk2\DR2, has a bad block.
Odradio sam checksm /r i bukvalno svaku sekund je taj error izbacao u event viewer a ranije cesto i pc mi je freezovao i crashovao, ne bi se ugasio na shutdown i sl ali eto nadjoh problem.
Sad se evo zavrsava checksm ali imam osjecaj da ce hdd polako da umre. Iz 2008 je i 600gb pa razmisljam sad da uzmem neki 1 ili 2 tb (koji je dobar?) a ovaj sta, sta jos da probam da ga spasem ili da se ne oslanjam na njega za ista?
Kod:
C:\Windows\system32>chkdsk E: /R
The type of the file system is NTFS.
Chkdsk cannot run because the volume is in use by another
process.  Chkdsk may run if this volume is dismounted first.
ALL OPENED HANDLES TO THIS VOLUME WOULD THEN BE INVALID.
Would you like to force a dismount on this volume? (Y/N) y
Volume dismounted.  All opened handles to this volume are now invalid.
Volume label is Programs and Games.
CHKDSK is verifying files (stage 1 of 5)...
  269056 file records processed.
File verification completed.
  111 large file records processed.
  0 bad file records processed.
  0 EA records processed.
  0 reparse records processed.
CHKDSK is verifying indexes (stage 2 of 5)...
  283040 index entries processed.
Index verification completed.
  0 unindexed files scanned.
  0 unindexed files recovered.
CHKDSK is verifying security descriptors (stage 3 of 5)...
  269056 file SDs/SIDs processed.
Security descriptor verification completed.
  6992 data files processed.
CHKDSK is verifying file data (stage 4 of 5)...
11 percent complete. (4148 of 269040 files processed)
Windows replaced bad clusters in file 4203
of name \PROGRA~1\Steam\STEAMA~1\common\DOTA2B~1\dota\resource\IT2B12~1.TXT.
11 percent complete. (16086 of 269040 files processed)
Windows replaced bad clusters in file 16117
of name \PROGRA~1\Steam\appcache\HTTPCA~1\58\58FF9F~1.
11 percent complete. (16405 of 269040 files processed)
Windows replaced bad clusters in file 16549
of name \PROGRA~1\Steam\tenfoot\resource\images\friends\FRIEND~1.PNG.
11 percent complete. (42951 of 269040 files processed)
Windows replaced bad clusters in file 42969
of name \PROGRA~1\Steam\STEAMA~1\common\Trine 2\_COMMO~1\DirectX\Jun2010\MAR200~
1.CAB.
11 percent complete. (48203 of 269040 files processed)
Windows replaced bad clusters in file 48245
of name \PROGRA~2\MICROS~1\Office15\ADDINS\POWERP~1\ko\MI63FB~1.DLL.
11 percent complete. (48229 of 269040 files processed)
Windows replaced bad clusters in file 48246
of name \PROGRA~2\MICROS~1\Office15\ADDINS\POWERP~1\nl\MI63FB~1.DLL.
11 percent complete. (48230 of 269040 files processed)
Windows replaced bad clusters in file 48247
of name \PROGRA~2\MICROS~1\Office15\ADDINS\POWERP~1\no\MI63FB~1.DLL.
11 percent complete. (48231 of 269040 files processed)
Windows replaced bad clusters in file 48248
of name \PROGRA~2\MICROS~1\Office15\ADDINS\POWERP~1\pl\MI63FB~1.DLL.
11 percent complete. (48232 of 269040 files processed)
Windows replaced bad clusters in file 48249
of name \PROGRA~2\MICROS~1\Office15\ADDINS\POWERP~1\pt\MI63FB~1.DLL.
11 percent complete. (48233 of 269040 files processed)
Windows replaced bad clusters in file 48250
of name \PROGRA~2\MICROS~1\Office15\ADDINS\POWERP~1\ro\MI63FB~1.DLL.
11 percent complete. (48234 of 269040 files processed)
Windows replaced bad clusters in file 48251
of name \PROGRA~2\MICROS~1\Office15\ADDINS\POWERP~1\ru\MI63FB~1.DLL.
11 percent complete. (48235 of 269040 files processed)
Windows replaced bad clusters in file 48252
of name \PROGRA~2\MICROS~1\Office15\ADDINS\POWERP~1\hr\MI63FB~1.DLL.
11 percent complete. (51094 of 269040 files processed)
Windows replaced bad clusters in file 51171
of name \PROGRA~1\Steam\STEAMA~1\common\STEALT~1\DOCUME~1\HELPHE~2.HTM.
11 percent complete. (51155 of 269040 files processed)
Windows replaced bad clusters in file 51172
of name \PROGRA~1\Steam\STEAMA~1\common\STEALT~1\DOCUME~1\HELPHE~3.HTM.
11 percent complete. (51156 of 269040 files processed)
Windows replaced bad clusters in file 51252
of name \PROGRA~1\Steam\STEAMA~1\common\STEALT~1\DOCUME~1\source\_108.htm.
11 percent complete. (51236 of 269040 files processed)
Windows replaced bad clusters in file 51253
of name \PROGRA~1\Steam\STEAMA~1\common\STEALT~1\DOCUME~1\source\_109.htm.
  269040 files processed.
File data verification completed.
CHKDSK is verifying free space (stage 5 of 5)...
  91182823 free clusters processed.
Free space verification is complete.
Adding 48475 bad clusters to the Bad Clusters File.
Correcting errors in the Volume Bitmap.
Windows has made corrections to the file system.
 625129471 KB total disk space.
 259961952 KB in 150832 files.
     75180 KB in 6994 indexes.
    193900 KB in bad sectors.
    355839 KB in use by the system.
     65536 KB occupied by the log file.
 364542600 KB available on disk.
      4096 bytes in each allocation unit.
 156282367 total allocation units on disk.
  91135650 allocation units available on disk.
Za početak proveri kablove da nisu možda naprsli (SATA data i SATA power connector),
ako jesu onda problem može biti do njih (kao i do lošeg napajanja).
Čest slučaj je da problem sa HDD-ovima nastane od lošeg napajanja ili loših kablova.
Ako je napajanje OK i dobri konektori... Vadi podatke i oprosti se od diska.
...a pre nego li ga bacis provuci ga kroz hddregenerator, MOZDA rezultat bude povoljan I mozda budes mogao da ga koristis bilo kako.
Proveri sta kaze Hard Disk Sentinel. Ako je Health ispod 70%, mozes slobodno da ga bacis u kantu.
Nije vredno da se bakces time, samo spasi podatke koji ti trebaju i kupi novi hard.
Pokrenuo HDD regenerator nasao neke bad sectore popravljao neke ali racku, drive is not ready greska. Pretpostavljam da je to to crkava, srecom na hddu sve sto imam je steam folder koji kopiram trenutno, office, fraps, upay i origin tako da nema neke glavobolje oko podataka. Da je bio drugi hdd koji sam se uplasio da je, storage koji je 99% full lose bi bilo :D
Jedno pitanje: sta da radim sa ovim HDDom? Prodam ga neko za male pare, naznaceno naravno da ima bad sectore.
Da, prodas ga za par stotina dinara ili poklonis nekome.
Bio sam spreman novi hdd da narucim danas a ovaj bacim ali sam low level formatirao, odradio chkdsk /r opet i hdd regenerator pustio, kao i WD lifeguard kratki i extended test i sve je prosao, izgleda da se popravio? regen je popravio jedan bad sector i to je to. Zadrzat cu ga za sad da ne bacam pare na novi, ako krene opet novi odmah uzimam, a do tad cu pravit backups redovno.
