GTA IV - Resenja problema -> Patchevi -> Tweakovi
STUPAR
Commandline.txt
Otključava sva grafička podešavanja i isključuje vsync. Kopirajte ga u maticni GTA IV folder. Ovde je spisak svih komandi:
HTML:
#Tools
#-benchmark: Runs the benchmark tool and immediately exits game.
#-help: Display list of all command line options
#Graphics
#-renderquality: Set the render quality of the game. (0-4)
#-shadowdensity: Set the shadow density of the game. (0-16)
#-texturequality: Set the texture quality of the game. (0-2)
#-viewdistance: Set the view distance of the game (0-99)
#-detailquality: Set the detail quality of the game. (0-99)
#-novblank: Disable wait for vblank (No Vsync)
#-norestrictions: Do not limit graphics settings
#-width: Set width of main render window (default is 800)
#-height: Set height of main render window (default is 600)
#-safemode: Run the graphics in the lowest setting possible
#-frameLimit: Limit frame to interval of refresh rate
#-refreshrate: Set the refresh rate of main render window
#-fullscreen: Force fullscreen mode
#-windowed: Force windowed mode
#-availablevidmem: Set amount of physical Video Memory
#-percentvidmem: Percentage of video memory to make available to GTA
#Audio
#-fullspecaudio: Force high-end CPU audio footprint
#-minspecaudio: Force low-end CPU audio footprint
#System
#-noprecache: Disable precache of resources
#-nomemrestrict: Disable memory restrictions -install the game and/or re-install DirectX
Kod:
http://www.filefactory.com/file/475c87/n/commandline_rar
Windows XP Service Pack 2 fix
Omogućuva igranje igre na XP SP2.
Kod:
Step 1: Run Regedit by Clicking on Start -> Run , type in regedit and press enter
Step 2: Make a backup of your registry (just in case)
Step 3: Browse to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\C ontr ol\Windows"
Step 4: Modify the value of "CSDVersion" from "0x00000200" (SP2) to the Windows XP SP3 value of "0x00000300"
Step 5: Close registry editor
Step 6: Reboot
Step 7: Start GTA and freakin enjoy it already!
Da bi vam igra radila bez problema obavezno instalirajte sledece:
GTA IV Patch - Link
Najnovije drajvere - Nvidia - ATI
.NET Framework 3.5 - Link
Naravno da bi vam igra radila normalno morate imati odgovarajuci hardware. Zvanicna minimalna i preporucena konfiguracija:
Minimum System Requirements
* OS: Windows Vista - Service Pack 1 / XP - Service Pack 3
* Processor: Intel Core 2 Duo 1.8Ghz, AMD Athlon X2 64 2.4Ghz
* Memory: 1.5GB, 16GB Free Hard Drive Space
* Video Card: 256MB NVIDIA 7900 / 256MB ATI X1900
Recommended System Requirements
* Processor: Intel Core 2 Quad 2.4Ghz, AMD Phenom X3 2.1Ghz
* Memory: 2 GB (Windows XP) 2.5 GB (Windows Vista)
* 18 GB Free Hard Drive Space
* Video Card: 512MB NVIDIA 8600 / 512MB ATI 3870
Ako imate "pijanu kameru", to znaci da koristite nelegalnu verziju igre.
P.S. Molio bih vas da ne spamujete u ovoj temi, neka sve bude pregledno.
ja bih napomenuo da je piraterija na forumu zabranjena. STUPAR je rekao koji je uzrok pijane kamere i koje je resenje. Svako pominjanje "lekica", "medicina" "popravki", itd... bice najstrozije sankcionisano!
SAVEGAME i BACKUP
Igra ima problema kad se koristi backup save, posle reinstalacije igre, ili kada se save prebaci sa jedne masine na drugu.
Prijavljuje gresku prilikom ucitavanja backup-ovanog sejva.
MOGUCE RESENJE (ali nisam isprobao):
Sacuvati ceo rockstar folder i xlive folder.
XP:
1) Backup "C:\documents and settings\Ime\Local Settings\Applicationdata\Microsoft\XLive"
2) Backup "C:\documents and settings\Ime\Local Settings\Applicationdata\Rockstar Games"
Vista:
1) Backup C:\Users\ime\AppData\Local\Microsoft\Xlive
2) Backup C:\Users\ime\Appdata\Local\Rockstar Games
3) Zameniti direktorijume 1) i 2) sa onim folderima koje ste sacuvali i koji sadrze sejv koji se zeli ucitati.
PROBLEMI SA (nedostajucim) TEKSTURAMA
Instaliran najnoviji drajver za graficku karticu, patchovana igra, igra radi ,ali nedostaje velika vecina tekstura/ili je sve u redu, ali se manji objekti "kasno" pojavljuju na sceni.
Riva Tuner je moguc uzrok ovog problema i, ako se koristi, treba instalirati 2.21 verziju istog.
Graficka ima problema sa kolicinom tekstura u Vram-u.Tada je moguce resenje da se setovanja (za view distance i texture) spuste na nizi nivo, i "poslusati savet" iz menija igre o zauzetosti video memorije.
To su zasad jedina moguca resenja, ako problem i dalje ostaje, mora se sacekati neko drugo resenje, drajver ili novi patch za igru.
Skinuti novi DirectX, posto septembarsko izdanje istog ima potvrdjene bugove u sebi.
http://www.microsoft.com/downloads/...56-c91a-4a8e-8bb8-9f20f1244a8e&DisplayLang=en
MOGUC PROBLEM SA (rotirajucom ili "padajucom") KAMEROM ili KONTROLERIMA UOPSTE
Posle instaliranja patcha kamera je pocela da se cudno ponasa (a nije u pitanju "pijana" kamera).
Najverovatniji uzrok je prikljucen kontroler na kompjuter (dzojped, volan ili nesto trece).Diskonektovanjem istog problem nestaje.
Detaljno uputstvo za ukljucivanje i koriscenje raznih kontrolera u GTA IV : http://www.gtaforums.com/index.php?showtopic=379477
GRAFICKA PODESAVANJA SE RESETUJU SVAKI PUT PRILIKOM POKRETANJA IGRE
Naslov sve kaze.Resenje je brisanje sadrzaja iz foldera:
XP: C:\documents and settings\Ime\Local Settings\Applicationdata\Rockstar Games\GTA IV\Settings
Vista: C:\Users\ime\Appdata\Local\Rockstar Games\GTA IV\Settings
Startujte igru i podesite ponovo sve.Posle toga igra pamti podesavanja (licno probao).
^Ovo vazi i dalje, a tema ce neko vreme biti sticky.
Sva pitanja i komentare vezane za igru postujte u zvanicnoj GTA IV temi.
Ако вам ова игра прави насумичне скокове и падове који нису везани за захтевност тренутног рендера на екрану, скините последњи DirectX (комплетну верзију - не web install) и покрените исталцију без обзира што га већ имате инсталираног. Решава проблеме, проверено, више пута, и то у свим играма.
http://download.microsoft.com/downl...-ab27-61f11024e97f/directx_nov2008_redist.exe
Hvala na info, pokusacu tako :)
U stvari tako i jeste,rade one 4 osnovne komande ali ove ostale da li moraju da se ubacuju u istom redu, ili ne?
Може у колико год хоћеш редова само све команде морају да имају један размак. Ево како мој изгледа.
-renderquality 2 -shadowdensity 0 -texturequality 2 -refreshrate 60 -frameLimit 50 -norestrictions -novblank -nomemrestrict
Ако скинеш -novblank имаћеш фрејмрејт који није закуцан на 22 због -refreshrate 60 -frameLimit 50.
Najnoviji driveri 181 resavaju problem iscrtavanja teksutura sa 7900 serijom grafickih kartica...Yeah
Poslednji put!
Ova tema sluzi samo za postovanje korisnih resenja i tweakova za igru, a ne za pitanja/probleme koje imate sa igrom.
Sva pitanja vezana za igru postavljajte samo u zvanicnoj temi!
Svaki dalji off topic bice sanksionisan!
Ako je bilo brisite.
Citam na forumima da se preporucuje iskljucivanje opcije snimanja klipova.
Evo za one koji nisu kopirali xlive save folder.Kopirajte ovaj modifikovani xlive.dll iz arhive u folder gde je instalirana igra i onda kopirajte bilo koji save u folder gde su sejvovi....
NAPOMENA:Ovaj xlive moze da radi samo sa jednim accountom, jer kad ga stavite on iskljucuje Windows Live iz igre (dugme "Home" vise ne radi) i ne moze da se prave vise accounta pa kome treba neka skine, jer video sam da na netu ima da se nadju sejvovi ali bez onog Xlive foldera. Pokusajte i ovo: kad ubacite save,krenite malo da igrate sa tim sajvom sto ste stavili,idite u kucu i usnimite...posle izadjite iz igre i obrisite ovaj xlive.dll iz foldera gta pa udjite ponovo u igru i trebalo bi da vam bude ukljucen ponovo windows live sa sve sejvovima sto ste ubacili, bar kod mene je tako radilo.
  • xlive.rar
    31 KB · Pregleda: 153
Nasao sam kako se moze resiti problem sa dzojstikom,ustvari procitao sam na jednom stranom forumu!Pre nego sto startujete igru iskljucite dzojstik iz USB-a,onda startujte!Kada pocinje Rockstar-ov logo onda ga ukljucite i to je to!Kod mene radi savrseno i vise nemam problema sa onom "padajucom" kamerom!
Fingerless Gloves
Open up the playerped.rpf file (With SparkIV), click on the name bar up top to sort by name and then and scroll down to find hands.
Export hand_001_r.wdr and hand_diff_001_a_whi.wtd files then change the 001 to 000 on their file names and re import them.
Press save and job done.
Tema
SparkIV
Kod mene :) :
Ako vec postujemo modove, evo jedan za ranac:
Tema
Za ubacivanje se koristi SparkIV
Evo i slika kod mene:
Gta 4 gamepad joypad dzojstik bug fix problem kamera camera
Da napomenem ovaj problem se javlja kod gamepada sa analognim odnosno pecurkama ili sisicama kako ih neki zovu.
Kada odradite sve sa gta foruma a kamera vam se zakucava u pod ili plafon ili se vrti u krug. Sta raditi ? :wall:
Mnogo sam mozgao da bi skapirao da svim ljudima koji imaju Logitech RumblePad 2 USB ovaj fix radi a negde sam procitao da treba u regeditu menjati ime vaseg (u mom slucaju Super Ultra Mega Kinez 3000 gamepad :p) u xbox controler for windows ili xna controler ali mi to nije radilo pa sam stoga probao da ga preimenujem u Logitech RumblePad 2 USB i gle cuda RADI. :banana:
Radite sledece:
1.Start/run ukucati regedit
2.Onda u registriju CTRL+F ili idite na find kako god vam je lakse, zatim ukucajte identicno ime vaseg kontrolera kao sto je upisan u vasem control panel/game contollers.
3.kada pronadje vas kontroler jednostavno oem vrednost imena zamenite sa "Logitech RumblePad 2 USB" (sve izmedju navodnika).
Napomena:eek:vaj postupak nisam probao bez prvobitnog koji je citiran iznad prema tome dabome.
I eto radi dzojpad gamepad dzojstik kako god volite da ga zovete.
:banana:puno zabave ljudi !!!:banana:
Few more tips to increase GTA 4 performance and other tweaks
How to unlock configuration files to manually edit GTA 4 settings
Unlike most other games, you can’t edit GTA 4 configuration settings by simply opening them up and editing them using a text editor. The game’s xlive (Windows Live) protection uses some kind of a hash check to detect modified files. If it detects edited files, the game will shut down at startup. Luckily the xlive protection, like all other protections out there, can be hoodwinked. Follow the steps below to unlock your GTA 4 configuration files for manual editing.
- If you have already tried modifying any GTA 4 configuration files (located in \Grand Theft Auto IV\common\data\ folder), you need to restore the original files. Reinstall if you have to.
- Download gtaiv.-magic.zip file from this link.(Link obtained from this thread – credit to original creator).
this link is what he is refering to. A more detailed ""STEP-BY-STEP instructions"" is provided in this thread (aka "credit to original creator", as stated above) *warning, long read and complex*.
- Extract this zip file – there will be two files inside – magic.bat file and filelist.pak file.
- Copy the magic.bat file to your GTA 4 installation directory. i.e- X:\Rockstar Games\Grand Theft Auto IV\
- Run magic.bat. This will create backups of your GTA 4 config files and prepare them for modding. You may need to right click magic.bat and ‘Run as Administrator’ on Windows Vista.
- Navigate to folder X:\….\Grand Theft Auto IV\pc\data\. Locate the filelist.pak file.
- Create a backup of filelist.pak. Then replace it with the filelist.pak file you extracted in step 3 above.
You will now be able to edit the configuration files. GTA 4 configuration files are located in the ]I]X:\…\Grand Theft Auto IV\common\data\[/i] folder. Just open the .DAT files in this directory with a text editor and you are good to go. If you are looking to tweak graphics settings, edit visualsettings.dat file.
How to turn off/reduce Bloom effect in GTA 4?
If you were not aware, GTA 4 has the bloom effect enabled by default. Worst part is that there is no option to turn it off. If you have low end video hardware, having bloom enabled can cost you some FPS. Although Bloom can never really be turned off in GTA 4, it can be turned down by editing the config files. To turn Bloom down, follow the steps below:
- You need to prepare your configuration files for modding by following steps 1-7 in ‘How to unlock configuration files to manually edit GTA 4 settings’ topic above. If you have not done this already, do it now.
- Navigate to X:\…\Grand Theft Auto IV\common\data\ folder. Locate the visualsettings.dat file. Check if the file is marked read only. If it is, remove the read only attribute.
- Open visualsettings.dat with a text editor. Search for the following lines:
--- misc.BloomIntensityClamp.HD 10
--- misc.BloomIntensityClamp.SD 10.00
Now carefully change these two lines to the ones given below:
--- misc.BloomIntensityClamp.HD 0
--- misc.BloomIntensityClamp.SD 0.00
- Save the file.
I cannot guarantee that you will always gain performance using the above method. On some video cards you will see a 5-10 FPS increase while on other cards there will be no noticeable performance increase at all.
P.S.- If GTA 4 crashes before intro screen when you launch the game after modding a file, something went wrong during the modding process. You may need to resintall.
Igra extra ( dok se igra-posto puca, ispada, zakucava i ostala sr*** )...
E, onda sam ( u besomucnom traganju za resenjem i normalnim igranjem ) naleteo na ovo :
Additional Speed: If you happen to be running Vista x86/x64 and you have a directx10 capable graphic card. Do what elecg2 figured out. I tried creating empty/easy HLSL shaders and putting them in GTAIV to get rid of shadows and stuff but that didn't work.
However by doing what elecg2 tried, I got a huge performance increase,
Go to GTAIV folder, go into common, then shaders.
Backup everything in there <- !!!
Then copy the contents of win32_30_atidx10, and paste them into win32_30_nv8. Or just rename the folders, whatever makes you happy.
That gave me a significant performance boost and I have no graphical problems or abnormalities. Try it, if it causes you problems or decreased performance then just put it back to normal. With these steps you can get your game running beautifully in no time, or at least better than before.
Odavde...
I sad leti ( doduse sa malo osakacenim texturama, ali-leti... ).
E, sad...razmisljam da prodam ovu ( iz potpisa ) 4870 karticu, kupljenu pre tri dana, a kupim 4870 GS, 1024 mb...
edit: Ovo radi, provereno i malo povecava fps (bar na ATI kartama).
Probajte da iskljucite VPU recover u CCC-u...
Meni je pruzilo 2 sata igranja bez i jednog problema.
Evo ga ( lakse mi je bilo ovde kao attachment nego u pp da hostujem sliku :) )
Pozdrav
    233.4 KB · Pregleda: 271
Moze li ovo za bloom neko da pojasni prilicno je nejasan terd sa koracima na linku THERD.:zgran:
Sta ti tacno nije jasno, daj da ti prevedemo. Prvo odradis korake 1-7 pa posle 1-5 za bloom.
Kojih sedam potpuno sam se pogubio u ovim koracima evo teksta iz terda.
Okay.. I guess the real point of this topic was to understand why the technique would work... and I provided the batch file only for simplicity but I guess a lot of people are having trouble with it.
Use opium/s0biet's loader patch if you can. This is a much more harder way to go about things, but its a logical way if you understand whats happening in the background.
There are essentially a few things going on here:
1. When the game loads, it opens files.txt and verifies the files in there -- this means, all of the files listed in files.txt need to be the original unmodified files... and all the files need to be in that list (just removing a file won't solve our problem).
2. In addition to verifying the files in files.txt, the game also loads a pre-cached copy of the files from filelist.pak.
3. When the game loads the real data from the files... it checks if it was in the precached filelist.pak. If not, it'll load from the real path of the file (not the path given in files.txt).
We cheat the verification system by:
1. Making copies of all the files in the files.txt list as filename.ext.magic
2. Modifying files.txt to point to the filename.ext.magic files.
3. Replacing filelist.pak with an empty file containing no files in the cached file list.
4. Editing the original files that the game looks for when it needs the data.
5. Now the game is fooled into checking the original files during the checking phase, but loads the modified files during the loading phase.
So.. step by step... here's what I would do:
1. Make sure you have all the original files (restore from backups if you don't... or worst case scenario reinstall/fix your install).
2. Make sure you can run the game and start/load a game and actually get in game. Don't use the loader if you're using this method.
3. Ensure that your windows is setup to show file extensions (In Explorer... Tools (ALT+T) -> Options -> View... Uncheck Hide extensions for known file types)
4. Ensure that your GTA IV directory/files are not readonly.... this is particularly important if you're on Vista and installed into Program Files -- I've seen some of my files there being write protected. To fix this, right click on the "Grand Theft Auto IV" folder, and click on Properties... uncheck Readonly and then click on OK.
5. Make a backup of pc\files\filelist.pak as filelist.pak.magic and overwrite it with the provided patched filelist.pak (the batch file doesn't do the overwriting with the patched file for you!)
6. Now, try modding one file.... for example, try the common\data\WeaponInfo.xml file. The changes are easily visible, and having a saved game doesn't affect the changes in the file. To mod this we will do the following:
6a. Make a copy of files.txt and call it files.txt.magic. (We're using .magic... but it could be anything you like... just name it differently) Don't ever ever edit any of the .magic files. If you did -- you messed up... start over again.
6b. Go into common\data and make a copy of WeaponInfo.xml and name it as WeaponInfo.xml.magic
6c. Edit common\data\WeaponInfo.xml and make your changes... for an easily visible example, check out opium's change here: http://www.gtaforums.com/index.php?showtop...st&p=1058712412
6d. Edit files.txt with notepad...
6e. Find the line saying "common\data\WeaponInfo.xml", and change it to "common\data\WeaponInfo.xml.magic" (no quotes)
6f. Find the line saying "pc\data\filelist.pak", and change it to "pc\data\filelist.pak.magic" (no quotes)
6g. Find the line saying "files.txt" (should be at the very bottom), and change it to "files.txt.magic" (no quotes again)
6h. What you've done now is to point checking part of the game to the WeaponInfo.xml.magic file but the game will still load WeaponInfo.xml when it needs to load the data. Run the game, and test your changes.
6i. If it didn't work at this point... you did something wrong -- don't go any further. If you're happy with the progress and don't mind doing the steps above for each file... don't go any further either!
7. Now that you've proven that it works for one file... you can use the batch file to "automagically" do it for all the files... but before we do, we have to undo the test changes we made in step 5/6. To do this:
7a. Delete common\data\WeaponInfo.xml and rename WeaponInfo.xml.magic to WeaponInfo.xml
7b. Delete files.txt, and rename files.txt.magic to files.txt
7c. Delete pc\data\filelist.pak and rename pc\data\filelist.pak.magic (We do this because the magic.bat will copy filelist.pak to filelist.pak.magic and screw everything up if filelist.pak is already patched before running the magic.bat file)
8. Now extract the magic.bat file to your GTAIV directory. Before you run it, make sure you have admin rights on your computer.
9. If you're on Vista, right click on magic.bat and click on Run as Administrator. Approve any UAC screen you get. If you're on XP, you can just double click on the magic.bat file.
10. When its complete... it has essentially completely done Step 6 for ALL the files mentioned in files.txt (i.e. it just saved you some trouble and some time).
11. Overwrite pc\data\filelist.pak with the provided patched filelist.pak (the batch file doesn't do the overwriting with the patched file for you!)
If you want to be extra safe... make backups of anything you edit (even though the .magic file essentially a backup).
Jel probao neko mod tj. neka vrsta hook-a - speed meter 0.1.4? Speedo
Ima na youtube-u kako sve izgleda i radi.
Konkretno nikako nece da se pokrene? Sve ide preko asi loadera ali konkretno pomenuti asi puca i nece da se startuje kako treba dok igra radi OK. Izashla je verzija source za 0.1.5 sto mi nista ne znachi.
I jel zna neko 1st person mod kako da se pokrene? Jako me smara kamera kada strejfujem sa likom kao da ima magnet pa vraca na pogled s ledja, kontam da bi mnogo bolje izgledalo u prvom licu ili bar sa zakonima kretanja kamere kao u 1st person pucachini..
Pa kad pritisneš desni taster da se napravi nišan, to je skoro ko first person, mislim tako se ponaša.
