Gigabyte GV-R485MC-1GH - Silent ATI Radeon HD 4850
Brazilko
Gigabyte GV-R485MC-1GH Graphic Card
"Utilising the AMD/ATI Radeon HD 4850 GPU with 1Gb of DDR3 ram, and featuring a unique custom cooling that's fanless ... the Gigabyte GV-R485MC-1GH gives good performance, with some great features on it."
Introduction
In this review, we'll be taking a look at the Gigabyte GV-R485MC-1GH graphics card. It's powered by ATI's already proven and powerful Radeon HD 4850 (RV770) GPU featuring 55nm technology, upto 480 processor streams, 1Gb of DDR3 ram, as well as supporting DX10.1, HDMI, HDCP and CrossfireX. To add to this, Gigabyte have also overclocked the GPU core slightly, from the standard clock of 625Mhz to 640Mhz, and they've done the same for the memory too ... from the satndard clock of 900Mhz to 960Mhz.
It's a decent card and should perform in-line with other Radeon HD 4850s on the market. However, what makes this card different is the fanless "Multi-Core" cooling technology which Gigabyte have included. It should appeal to a lot of gamers who cherish silence as well as some HTPC enthusiasts.
In our tests we'll be benchmarking the Gigabyte GV-R485MC-1GH with several GPU intensive DX10 games ... with both 4xAA and 16xAF options enabled, as well as your usual 3D Mark 2005, 2006 and Vantage tests. Our test rig includes an Intel Core 2 Quad Q6600 @ default 2.4Ghz, Gigabyte GA-X48 DQ6 (X48) motherboard, Kingston HyperX DDR2 PC2-9200 2Gb Kit, PC Power & Cooling Turbo Cool 860W PSU and a 24" Samsung SyncMaster 245B LCD monitor. All-in-all, it's a decently spec'd system for DX10 gaming.
Super HQ settings (4xAA, 16xAF, Highest/Ultra Quality)
Games/Software used
- F.E.A.R. (DX9)
- Call of Juarez (DX10)
- Crysis (DX10)
- 3D Mark 2005
- 3D Mark 2006
- 3D Mark Vantage
Catalyst Drivers v8.8
Verdict & Conclusion
Gigabyte's fanless and silent "Multi-Core" Cooling system finally gets to be featured on their Radeon HD 4850 graphic cards. After seeing it work so well on their Geforce 9600GT it was only natural to see this special cooling technology featured on their Radeon HD 4850 graphic cards too.
We put this card through 8 hours of heavy DX10 gaming and we were surprised to see that the "Multi-Core" cooloing technology was wroking flawlessly, with temperatures averaging around 48 degrees Celsius. It's definitely much cooler than what you would get from a stock cooler which can be in excess of 70 degrees Celsius. So, this is excellent news for the gaming enthusiast who love silence, but expect good performance from a card that won't heat up the system like a radiator.
Final words
The Gigabyte GV-R485MC-1GH with it's fanless "Multi-Core" cooling technology is ideal for any gamer and HTPC enthusiast who cherish silence. The "Multi-Core" cooling technology really lowers the GPU temperatures by as much as 15-20 degrees Celsius over a standard stock cooler. The overall performance is on par with other Radeon HD 4850s, so it's all good here ... but for the hardcore enthusiasts, you might want to look elsewhere.
Sad ce komentari tipa..."al bi joj prisio jednu 12-icu"! :)
cuj 12, sad su 14tice standard :D
iskreno, iznenadjen sam da su tolko dobre temperature sobzirom da je silent i da su 48xx prave pecnice...ono sto nisam procitao je u kom kucistu i sa kolko drugih ventova su je testirali.
Imam GIGABYTE 9600GT sa tim hadnjakom stavio sam 12ticu da duva ispod kartice, 25-30idle 45-50loadu. Cooler je extra u kombinaciji sa dobro prowetrenim kucistem.
Uuuu... al mi se svidja ova kartica! Koliko je dobro hladjenje toliko ce i da kosta:D.
ima li ovo negde kod nas da se pazari ?
... . .wooahh, obozhavam Gygabyte-ove silent kartice... perverzija...
Ok, sve je to lepo, ali meni je smesno da sajt koji treba da uradi bilo kakav review nekog hardvera prvo ne uradi domaci i sazna malo vise o proizvodu koji testira.
Kako da budem siguran da ono sto pricaju je tacno ako oni ne mogu da odvoje 5 minuta da provere informacije koje tvrde.
Upravo sam probao Gigabyte GV-R485OC-1GH sa Zalman kulerom.
Kuler se dosta cuje, dok je pri overkloku nadmasio Gainward HD4850 1GB.
Gigabyte:
GPU 775MHz, DDR3 1155MHz
Gainward GS:
GPU 730, DDR3 1160MHz.
Za malo je Gigabyte ostao u kucistu, ali odlucio je tisi kuler u korist Gainwarda.
P.S.:
Uz Gigabyte se dobija DVI-HDMI adapter i crossfire bridge, dok ovih stvari kod Gainwarda nema.
al znate mozda gde mogu da skinem driver-e za ovu graficku.nigde na netu nemogu da nadjem
nisi probao na AMD sajtu?
nema na ovo stranici.nasao sam model ali nema nigde da download-ujem drive-ere
nasao sam model na amd ali nema.hvala ti u svakom slucaju.trazicu na net ponovo,ako saznas slucajno gde ima javi.
Pa to su ti drajveri sto sam ti ostavio link, oni su univerzalni za maltene sve ATI kartice, slobodno skini njih i uzivaj.
A i ti bi, priznaj. :D
Fina kartica bas, npr. kada se igra ili klokuje stavi se neki fan reda radi samo i to na 5v i ono extra temp a u suprotnom nije ni potreban.
Zna li se cena kod nas?
imam ovu grafu pa ako neko moze da mi kaze ko je ima naravno kakve su vam temperature pri igranju i ovako
kod mene je to oko 65C kad ne igram a jos nisam proveravao prilikom igranja kolike su temp
dali je to OK i ako nije kako da resim problem ako je to problem
Jel' moze na PM gde si kupio i koliko si platio?
