Gigabyte DVB-T Hybrid TV Card GT-PTV-TAF-RH na Ubuntu 6.06?
Milos_SD
Mobilni telefon
Samsung Galaxy S8
Pristup internetu
  1. Kablovski internet
Pozdrav svima...
Imam ovu TV karticu, i zanima me kako da je namestim da radi u Ubuntu-u?
KDETV radi (ima slika, ali nema zvuk).
Evo dela dmesg-a koji se tice ove kartice:
Kod:
[4299740.774000] saa7134 ALSA driver for DMA sound unloaded
[4299761.808000] saa7130/34: v4l2 driver version 0.2.14 loaded
[4299761.810000] ACPI: PCI Interrupt 0000:02:02.0[A] -> GSI 22 (level, low) -> I RQ 217
[4299761.810000] saa7133[0]: found at 0000:02:02.0, rev: 209, irq: 217, latency:  32, mmio: 0xf3004000
[4299761.810000] saa7133[0]: subsystem: 1458:9002, board: Philips Tiger referenc e design [card=81,insmod option]
[4299761.810000] saa7133[0]: board init: gpio is c040000
[4299761.936000] tuner 0-004b: chip found @ 0x96 (saa7133[0])
[4299761.964000] tuner 0-004b: setting tuner address to 61
[4299761.989000] tuner 0-004b: tuner: type set to tda8290+75a
[4299762.047000] saa7133[0]: i2c eeprom 00: 58 14 02 90 54 20 1c 00 43 43 a9 1c 55 d2 b2 92
[4299762.047000] saa7133[0]: i2c eeprom 10: ff ff ff 0f ff 20 ff ff ff ff ff ff ff ff ff ff
[4299762.047000] saa7133[0]: i2c eeprom 20: 01 40 01 02 02 01 01 03 08 ff 00 c1 ff ff ff ff
[4299762.047000] saa7133[0]: i2c eeprom 30: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[4299762.047000] saa7133[0]: i2c eeprom 40: ff 21 00 c2 96 10 03 32 15 50 ff ff ff ff ff ff
[4299762.047000] saa7133[0]: i2c eeprom 50: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[4299762.047000] saa7133[0]: i2c eeprom 60: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[4299762.048000] saa7133[0]: i2c eeprom 70: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[4299763.967000] saa7133[0]: registered device video0 [v4l2]
[4299763.968000] saa7133[0]: registered device vbi0
[4299764.173000] saa7134 ALSA driver for DMA sound loaded
[4299764.173000] saa7133[0]/alsa: saa7133[0] at 0xf3004000 irq 217 registered as  card -1
A evo sta kaze lspci:
Kod:
0000:02:02.0 Multimedia controller: Philips Semiconductors SAA7133 Video Broadcast Decoder (rev d1)
Mene zanima kako da ja namestim ovu karticu da pri gledanju TV programa imam zvuk, i kako da namestim da mi radi FM radio (nemam /dev/radio, a ni /dev/radio0 - ako stavim sudo modprobe saa7134 card=78 tuner=54 gbuffers=32 vbibufs=32 audio_ddep=10 tsbufs=32 oss=1 onda imam /dev/radio0), ali mi opet ne radi zvuk. :(
Hvala.
