Geovision gv1000 i USB dongle
M038
Pokusao sam da skinem neki noviji softver za karticu za video nadzor medjutim za registrovanje mi je potreban "USB dongle" jel neko zna sta uopste treba raditi,ovo mi je opis sa sajta:
The following download files are for upgrading from V6.0.0.0 to V7.0 only. To upgrade successfully, you will need at least version 6.0.0.0 of the same software properly installed in your PC. Version 7.0 requires DirectX 9.0 C or later. Please download DirectX 9.0 C in the following link to upgrade if necessary.
USB dongle is required to upgrade to version 7.0. USB dongle is provided through distributors and only against bar code (found on the capture card, CD bag, manual, and box that come with the package). Please provide your bar code to your supplier if needed to upgrade. Handling fee may be applied. It may take up to 4 weeks for your supplier to provide the dongle, as it is the lead-time required and distributors are not required to stock this item. We thank for your kind understanding and sorry if the upgrade has caused you any inconvenience.
U ovom kontekstu USB dongle je hard-lock. Hardverski uredjaj koji mora biti prisutan na racunaru tokom instalacije i koriscenja programa. Ovim se proizvodjac programa stiti od neovlascenog koriscenja programa (citaj: piraterije).
Ranije su se hard-lockovi kacili na paralelne portove, a sad idu i na USB.
Pozdrav
mogu li ja nekako da umnzim usb dongle,ukoliko nabavim jedan, da na obican usb flash stick prebacim softver ili slicno
