Forceware 190.62 WHQL + Compute Shader
nex999
Moderator
Super Moderator
CPU & Cooler
Core i9 14900KF*Noctua NH-D15
Matična ploča
MSI MAG Z790 Tomahawk WiFi
RAM
Corsair Vengeance DDR5 64GB 6400MHz
GPU
Asus TUF RTX4090
Storage
2x 2TB Samsung 990 PRO NVMe M.2
PSU
Corsair HX1500i
Kućište
NZXT H7 Flow
Monitor
LG Ultragear 27GS95QE-B, LG CX
http://www.nvidia.com/object/winxp_190.62_whql.html
http://www.nvidia.com/object/winxp64_190.62_whql.html
http://www.nvidia.com/object/win7_winvista_32bit_190.62_whql.html
http://www.nvidia.com/object/win7_winvista_64bit_190.62_whql.html
This is a WHQL-Certified driver for GeForce 6, 7, 8, 9, 100, and 200-series desktop GPUs and ION GPUs.
New in Release 190.62
* Adds WHQL support on Windows 7 for Microsoft’s new DirectX GPU Computing API: DirectCompute.
* Optimized for the latest PhysX gaming titles: Batman: Arkham Asylum and Darkest of Days.
* Installs PhysX System Software version 9.09.0814.
* Includes several bug fixes. More information can be found in the release documentation.
* What is your Windows 7 upgrade plan? Take a Quick Survey.
New in Release 190
* Adds support for OpenGL 3.1
* Adds support for CUDA 2.3 for improved performance in GPU Computing applications. See CUDA Zone for more details.
* Adds a new user-controlled power management setting for select GeForce 9-series and later graphics cards (only available on cards that already support more than one power state). This option allows users to set a performance level for each DirectX or OpenGL application.
* Includes several new control panel features and numerous bug fixes. More information can be found in the release documentation.
* Users without US English operating systems can select their language and download the International driver here.
Existing Support:
* Supports Microsoft’s new DirectX Compute API on Windows 7.
* Supports single GPU and NVIDIA SLI technology on DirectX 9, DirectX 10, and OpenGL,including 3-way SLI, Quad SLI, and SLI support on SLI-certified Intel X58-based motherboards.
* Supports NVIDIA PhysX acceleration on a dedicated GeForce graphics card. Use one card for graphics and dedicate a different card for PhysX processing for game-changing physical effects. Learn more here.
* Supports GeForce Plus Power Pack #3. Download these FREE PhysX and CUDA applications now!
* Supports GPU overclocking and temperature monitoring by installing NVIDIA System Tools software.
NVIDIA GeForce GPUs and DirectCompute in Windows 7 Accelerate Digital Media Applications
DirectCompute will be distributed as part of the DirectX 11 API and is supported by NVIDIA’s current lineup of DirectX 10 GPUs.
Dobar Drajver bez ikakvih problema ko uvek sa nvidiom:d
