Minja
Vlasnici ASUS TV karti ce znati da cene ovu vest
http://auzol.narod.ru/index_e.html
Version 2.38 RC1
> Added full Native support for chip Philips SAA7133, SAA7135.
> Added Native support for HF module Philips TDA8275 (Silicon Tuner).
> Added Native support for TV tuners LifeView FlyPlatinum 33/35,
YUAN FunTV-900, Asus TV FM-7135.
> Added feature enable/disable virtual sound effects for chip
> Added feature for capture sound, using built-in audio ADC with
sampling rate 48kHz for chip Philips SAA7133, SAA7135.
> Improved mode for making screenshot and multi-snapshot.
> Improved video processing for preview and capture.
> Improved deinterlace algorithm Blend Fields.
> Added feature Splash Screen at videosignal missing.
> Added feature fill frame borders by black color.
> Added action for mouse "Right click + Wheel".
> Improved interface with use Windows large font and at using some themes
Windows XP.
> Fixed bug under Windows98 for mode "Video on desktop", if Active Desktop
is active.
> Fixed bug with missing sound in NICAM standard after restore Windows from
Hibernate/Suspend mode.
> Fixed bug with missing sound at some external actions.
> More improvements.
> Some bug fixes.
edit: download je toliko spor da je to bruka, valjda ce ga prebaciti u download sekciju i na mirror siteu. Ipak, program i nije veliki ~1 MB pa skidanje traje nekih 25 min :d
Version 2.38 RC1
Windows XP.
is active.
> More improvements.
> Some bug fixes.
