firmware za LG GCE-8160b
Swiper
zeleo bih da upgrade-ujem firmware za moj rezach ali imam mali problem... video sam na netu ovo
Installation Instructions for Firmware Upgrade to version 2.01
for the LG Brand of the GCE-8160B
Improper processing of this upgrade will damage the drive. LG Electronics is not responsible or liable for improper installation of this upgrade.
This firmware upgrade is for firmware versions below 2.01 of the LG Branded GCE-8160B CD-RW drives only – Do not use for LG drives purchased in France.
The ROM version is stamped on the top of the drive below the serial number.
This upgrade is not designed for drives manufactured HP, IBM, Compaq, Dell or any other OEM {Original Equipment Manufacturer} customers, please contact the OEM for all firmware updates and support for your OEM drive.
e sada.. kako ja da znam da li smem moj rezach da upgradeujem ili ne ??? i da li se moze upgrade-om postoci da se vise ne kolje sa nekim medijima kao sto se trenutno kolje sa Verbatimom tj da li to ima uopste veze? :)
ps: mozda ce vam nesto pomoci to sto mi rezach prijavljyuje kao HL-DT-ST CD-RW GCE-8160B
Slobodno flashuj. Ja sam prosle nedelje probao pogresnim firmware-om da flashujem i nije htelo. Ocigledno je da taj firmware odgovara tvom rezacu tako da flashuj bez predrasuda. Mozda ti resi probleme, mozda ne, ali bitno je da se menja nesto, najgore je stajati u mestu.
