DX 9 info...
Mare
DirectX9 will go live in Q3 of this year, and DirectX9.1 in March, 2003. Delivery of Longhorn is probably going to impact what goes in DX9.1, but DX9 is definitely targeted at this Christmas' games.
DX9 will have improvements that will allow better optimizations and clearer controls within the vertex and pixel shader. DX9 doesn't look like it's going to have an advertising campaign to promote it, because it is very much an evolution designed for developers that struggled with programmable shaders first time around, and features that didn't quite deliver on their promise. It isn't a dramatic change from DX8.x.
It also doesn't look like it is going to require major driver modifications for the hardware guys either, although it does leave room for hardware improvements in next generation chips in stenciling, anti-aliasing, and texture handling
Moj komentar je : "blah..."
P.S. oni ni dx7 ne koriste dovoljno a sad opet krece dx9...ma koga uopste za**le za dx ?:p
A bre filipenko, jel ti samo skupljas postove ili sta.... Pa ovo nije tred za tebe....
Mislim da ce DX9 ipak preoteti jos od OpenGL-a kada je zabavni softver u pitanju... Laksi je za implementaciju, cak ce i Carmack poceti da ga koristi - Unreal je od sada D3D engine, isto tako i LithTech, Breed i svi ostali... a i igre koje se prave za X-Box ofcourse...
Inace ovo je info sa Tominog sajta. Dok se na tehnickim forumima prica da DX9 ulazi u beta fazu za oko 30 dana, dakle imace celo leto da ga lepo srede.
Ovo je sa jednog stranog foruma, nisam probao da li radi.
Hoce li neko da bude BETA tester?
http://www.nvplanet.com/article.php?sid=3
"Microsoft needs some beta testers for the future DirectX 9.
If you want to participate to the Beta Test Program, just follow these instructions and you might have the chance to get into the Beta test program.
Go to Beta Place
Use this login and password :
User-ID: DX9Beta
Password: DX9Gaming"
https://www.betaplace.com/betaplace...w.betaplace.com/betaplace/content/bphome.asp?
byMaX je napisao(la):
Ma bre ja hocu samo da kazem da ni sve funkcije Dx7 jos nisu implementirane u 90% igara a oni objavljuju uporno 1 za drugim DX-eve...ko da su nenormalni...i ovaj ce doneti to sto ce doneti, za jedno 2-3 godine to ce da bude ubaceno a do tada ce biti Dx12 (ili mozda DxXP :D)
BTW DX je laksi programerima malo, ali OpenGL radi po prostom dobrom starom principu : Ukjlucis-iskljucis...Ne verujem da ce bas tako lako najjaci programeri preci na Dx u potpunosti a da ce OpenGL da zamre...videcemo mi jos dosta od njega...
Mada ne sporim da buducnost najverovatnije pripada D3D-u...:(
BTW Lithtechov engine je verovatno najveca glupost od svih postojecih u poredjenju sa njima, a zamolio bih te i da mi navedes neku igru sa breed engine-om...(ili ja nisam bas tako dobro obavesten :confused: )
P.S. samo zabatali me onog : Izaci ce za 1 godinu-2 neki hit tipa Duke 4Never sa tim engine-om :D)
Pazi, to uopste nije tacno.... DX 7 je implementiran u sve igre koje su izlazile u poslednje dve godine... od MaX Payne-a do Nascar racing-a (FIFE, NBA i ostale... LithTech igre...)
LithTech igre su pravi primer ga OGL ostaje u upotrebi.
GlobalO je tipican primer koliko je LithTech krs.
I to jos secka!!!
Jedino ako su programeri nesto zeznuli.
Mada ako Joca uzme stvar u svoje ruke ko zna.
Mislio sam u potpunosti implementiran.
Inace taj Littech je takav krsch[tm] da je to nevidjeno. I strasno zahtevan. Npr. AvP2 ne bih apsolutno nikada igrao da nije one sjajne atmosfere. Igra je na momente, pogotovo napolju, delovala odvratno, ne zbog graficke, vec zbog samog endzina koji je najlepsi u mraku :)
