Da li neko zna gde bih mogao da nadjem Procomm plus 4.8
Setac
Da li neko zna gde bih mogao da nadjem Procomm plus 4.8, ili neki slican program
"The leader in terminal emulation.
Procomm Plus gives you unsurpassed versatility and reliability for terminal emulation and file transfers. By supporting over 30 different terminals, it lets you access almost any host system you can imagine. Transfer files with the assurance of optimum data integrity, and run full screen host applications for easy viewing. IS professionals worldwide rely on Procomm Plus for point and click access to a wide range of corporate hosts and online systems from anywhere. "
hvala puno
:wave;
Ne znam da li bi ste ga koristili za neki specifican protokol, ali se meni najvise svidja ZOC.
download (oko 1.2MB) na:
ftp://ftp.ger.emtec.com/zoc/zoc405_win_english.exe
ovo dole su o njemu napisali autori:
This powerful terminal emulator and telnet client is well known for it's outstanding user interface. It lets you access character based hosts via telnet, modem, Secure Shell (SSH/SSH2), ISDN and other means of communication. It can be used to connect to Unix/Linux hosts and shell accounts, BBSes, 3270 mainframes (via TN3270 emulation) or internet muds.
It's functions (like typed command history, scrollback, multiple window support, etc.) make it the preferred tool for people who have to access Unix shell accounts from a Windows platform. Linux admins will feel like sitting on their native console with ZOC's support for the Linux emulation with full colors, meta-keys and local printing.
Besides that, ZOC supports vt102, vt220 and several types of ansi as well as Wyse, TVI, TN3270 and Sun's CDE. ZOC also features major file transfer protocols like X-, Y- and Zmodem as well as Kermit and others. All these are offered in solid implementations that leave nothing to be desired.
ZOC is highly configurable and offers the usual terminal features like keyboard redefinition and scroll back buffer as well as some advanced and unique features among which are like a powerful script language, automatic triggering of actions based on received or typed text or a line trace feature
Hvala na pomoci
probao sam programcic,
imam samo problema nisam uspeo da provalim kako da korisitm funkcije user name and password, meni treba jedan dobar programcic za komunikaciju sa bbs-om
krck
verzija sa linka je shareware, a neke funkcije u njoj su iskljucene. Skinite ovaj zip koji sam prihevtao, i sredite zoc da bude pro.
Hvala jos jednom vec nasao crack
veliko hvala na pomoci vec sam nasao taj crack, ali imam malo problema pri logovanju na bbs, da li mozda znas jos neki program???cheers
Moji prijatelji kojima je telnet bio bitan koristili su (96-97) i procom 1.0, kad su izasle novije verzije procoma onda su se kleli da im ne rade kako valja i da je 1.0 bila zakon. U principu cini mi se da je stvar navike i da se kod ovih stvari treba poprilicno nazezati da bi comunikacija glatko proradila. Ja bih na vasem mestu kontaktirao tehnicku podrsku tog bbs-a i video sta oni preporucuju i kakva setovanja treba da budu.
U principu lako cete na mrezi naci dosta programa za ovo, samo npr. u google otkucate telnet AND freeware, ili nesto slicno (evo jednog finog linka sa par komada:) http://www.thefreesite.com/Free_Software/Telnet_freeware/
Nesto se ne secam da sam probao nesto drugo osim zmodema, al` bi trebalo da npr. bitware ili freevoice (koji dolaze sa modemima) zavrse posao.
