Core clock problem sa R9 280 ASUS TOP
DesertFox9449
Poštovan
Nedavno sam otkrio da moj graficki procesor smanjuje radni takt pri ulasku u bilo koju igru. Jezgro ide sa 980 mhz na 874 mhz cim udjem u igru bez obzira sto je core usage 100%. Probao sam Heaven benchmark na 980 mhz i radi, zatim sam overklokovao na 1200 mhz gde opet radi sa velikim rastom u FPS i temperaturi (55c MAX), a onda sam pokusao da udjem u game da bi mi na monitoru opet pokazivalo 874 mhz pod punim opterecenjem. Ako posle igre udjem ponovo u Heaven benchmark sta god da menjam u Afterburner-u ili GPU Tweak-u core clock ostaje na 874 mhz dok ne restartujem racunar. Problem do kartice, drivera (update-ovan), BIOSA??? Kartica je jos u garanciji.
https://drive.google.com/open?id=0B0fWdOxmDVcEaDh4S1daSFB4cms
https://drive.google.com/open?id=0B0fWdOxmDVcETEs1QV9kVWJ0T2s
razlika u benchmarku
https://drive.google.com/open?id=0B0fWdOxmDVcEamcwRjl2VnBnNzQ
https://drive.google.com/open?id=0B0fWdOxmDVcEX0tvalVad2s0TDg
    39.3 KB · Pregleda: 71
    39.9 KB · Pregleda: 76
Ажурирај MSI Аfterburner на 4.3.0 верзију па чекирај Erase autosaved startup settings.
Added “Erase autosaved startup settings” option to “AMD compatibility properties” section in “General” tab. Starting from AMD Crimson drivers family, the driver is automatically saving hardware settings (e.g. overclocking or fan control settings) in the registry and apply it at Windows startup. It makes settings of any third party hardware overclocking tool virtually permanent, meaning that applied settings stay in the system even after rebooting or powering down the system. However, such implementation is unsafe and even potentially dangerous, because you're no longer able to undo unsafe overclocking with system reboot or even driver reinstall. To prevent such situations, MSI Afterburner can now optionally erase AMD driver's autosaved startup settings after applying new settings to hardware
Pobrisi sva ****** i koristi samo wattman ili samo MSI ab. Ako imas vise tih programa instaliranih znaju da prave ******.
trotluje ti gpu na opetrećenju. treba da povećaš power limit u katalist/overdrive. stavi slobodno na +20%.
imaš i opciju editovanja biosa, ako nećeš da se akaš stalno sa katalist opcijama. u svakom slučaju, isprobaj pa kaži.
Ni to nije pomoglo. Jedino da probam nesto u BIOS-u.
sačuvaj bios pomoću gpu-z i okači ga ovde kao attachment, srediću ti ja.
Instaliraj 16.7.2 drajver pa javi rezultat.
Pre toga možeš da probaš sa ugašenim xbox DVR-om ako imaš Win10.
Desert Foxe, Erwine Rommele, za svaki slučaj si trebao da mi pošalješ svoj bios pomoću GPU-Z, zbog mogućeg problema sa drugim memorijskim modulima,
ali evo tebi sad sređen bios (sa techpowerupa) koji bi trebao da ti sredi throttle. (zipovan je, raspakuj ga prvo na flešku)
nije potrebno brisanje/reinstalacija drajvera itd. samo fleš. Nadam se da umeš to da izvedeš.
Najlakše ćeš da proveriš sa afterburnerom i kombustorom. Pustiš kombustor i pratiš gpu usage. Treba da bude konstantno zakucan na 100%, bez padova.
  • nov.zip
    96.3 KB · Pregleda: 23
Cenim trud. Probacu cim budem imao vremena pa javljam rezultat.
