chkdsk pri svakom startovanju lap-topa
savatije
Prvo pozdrav !
ovo je moj prvi post na ovom forumu , nazalost , vezan za problem:
od pre neki dan, pri svakom podizanju sistema ( W7 x64 Home premium (genuine)) radi mi chkdsk. Od guglanja sam nasao nekoliko indenticnih resenja , primenio i to se danas vise ne dogadja.
procedura je ova:
Well, that's easy. First click Start> Run> bring up a command prompt by typing in "CMD" and type " fsutil dirty query d: ". This queries the drive, and more than likely it will tell you that it is dirty. Next, type "CHKNTFS /X c:". The X tells Windows to NOT check that particular drive on the next reboot. At this time, manually reboot your computer, it should not do a Chkdsk and take you directly to Windows.
Once Windows has fully loaded, bring up another CMD prompt and type and now you want to do a Chkdsk manually by typing "Chkdsk /r c:". This should take you through 5 stages of the scan and will unset that dirty bit. Finally, type "fsutil dirty query c:" and Windows will confirm that the dirty bit is not set on that drive. Good luck!
medjutim i dalje nakon provere " fsutil dirty query c:" prijavljuje mi da je disk "dirty" , jednostavno me iritira...
lap-top DELL inspiron r17 n7110, svez OS , kompletno updejtovan....
ima li ko ideju kako da se resim prljavstine?
unapred hvala na odgovorima
Hvala Danilo, sled stvari je tacno kao sto je opisano u clanku, prvo update ( od pre par dana ) i onda pocinje chkdsk...da situacija bude kompletna, koristim KAV kao avir ( Kaspersky internet security). Probacu neka od predlozenih resenja.
