Chieftec sa napajanjem do 100 eura?
Air Jordan
U firmi hoce iskljucivo Chieftec. Postoji li neka serija koja se najbolje pokazala i koji bi model bio dobar izbor?
Mislim da se trazi Kuciste sa napajanjem a ne samo napajanje :)
Cini mi se da sa svim kucistima uglavnom dolaze Delta napajanja, eventualno neki Sirtec. Mi ih isto imamo na poslu, za poslovne masine bez jakih grafickih kartica rade skroz korektno.
I ja tako mislim.
Serija cega ? Kucista ili napajanja, ili i jednog i drugog.
Tesko je kupiti i ok kuciste i ok napajanje, oboje Chieftec, ukupno za 100e.
Onda je bolje kupiti neko solidno Chieftec napajanje (ako bas mora Ch) i neko najobicnije kuciste.
Turbo serija, CFT-600-14C(S) i slicna od 650, 700W..
Jel momak, si razmisljao da pocnes da ravis sopstvena napajanja :d.
Ko o cemu baba o ustipcima :p.
Ajd kad si vec tu :D, sta mislis, o napajanju OCZ PC Power&Cooling 610W Silencer 8cm fan/EPS/SLI/80 PLUS ?
Treba mi kvalitetno napajanje, ekstra tiho :), da li ovo svojim kvalitetom opravdava cenu od ~95e ?
I gde ga ima?
Evo sta kaze SPCR:
The acoustic performance is fairly good, staying modest in our test setup till well past 300W, which is about as high a peak load as you'll encounter in a sane quiet PC. Above this power level, the fan noise rose to a higher level than any other PSU tested in recent memory. It's a moot point as anything above 30 dBA@1m or so is simply too loud, but the fan behavior is indicative of a decision to keep the unit well-cooled, especially at higher load, even at the cost of higher noise. That high speed 80mm fan does not scale down well; its sound signature at idle is not particularly benign. In a quiet room (installed in an otherwise quiet PC), it will be easily heard, and many listeners will hear it as being at least mildly annoying, due to the complex mix of tonal sounds.
At $110~120, the Silencer 610 is competitively priced with other high profile quiet PSU brands such as Corsair, Enermax, Seasonic or Silverstone. The 5-year warranty is very generous. Acoustically, it does not match the quietest models from these brands, so for the core SPCR audience, it is hard to recommend this unit over others. However, if an 80mm fan in-line fan design is more to your liking than the 120mm fan designs that prevail, if the PC Power & Cooling brand has always pulled you, and if reduced noise is what you seek acoustically, then the Silencer 610's fine electrical performance and well-cooled behavior may be a perfect fit.
Chief ima jacu 12V granu + je modularan.
