60% po starom.
If you have activated your ChatSim before May 5th, 2015 you have to use your ChatSim no more than 60% in the same zone. For example if you use your ChatSim for the 55% in Germany and for another 45% in the USA, you can send unlimited text messages and emoji. If you have actived a ChatSim after May 5th, 2015, you can simply use it in a personal way, responsibly and in compliance. It refers to an improper use, if it is repeatedly exceeded the average daily traffic, where average daily traffic refers to the the average traffic exchanged by all ChatSim active with the only fee of 10 €.The improper use may result in the temporary suspension of the service and in case of repeated suspensions, the Sim will be disabled.
