Canon 40D firmware 1.1.1
audiofreak
Banned
Banovan
Ispravke:
1. Fixes a malfunction that in rare occurrence causes a low battery indication to be displayed when using the EF 85mm F1.2L II USM lens. Depending on the battery check timing of the camera, the battery level displayed on the camera's LCD data panel may show Battery will be exhausted soon or Battery must be recharged, even though the battery capacity is sufficient.
2. Fixes a malfunction that in rare occurrence causes an Err 06 Self Cleaning Sensor malfunction to appear on the camera's LCD monitor and LCD data panel, even when the Self Cleaning Sensor Unit is operating normally. This message may appear depending on the timing of when the camera is switch to the ON position.
3. Fixes a malfunction that prevents correct colors from being printed when direct printing. RAW images captured using the camera's custom Picture Styles (Emerald, etc.), which have been downloaded from Canon's Web site and registered under User Def. 2 or User Def. 3.
4. Modifies the level of subject brightness that causes the AF-assist beam to fire when using an external Speedlite.
5. Enables an external flash connected to the camera's synchro terminal to fire even when the camera's built-in flash is popped up.
Link
Jel ce biti neki firmware za 1000d uskoro?
hehe,dobro radi sad:D
Mislim da za te slabije aparate ni ne ispravljaju greske :d
tiha is pulling your leg :d
A jel ti imas neki konkretan problem sa 1000D pa da ti treba firmware update ili samo volis da imas najnovije verzije svega i svacega?
Pitam zato sto sam ja video err 06 kod mene jednom u toku rada (i resio ga se tako sto sam izvadio i vratio bateriju) pa me to sto su je ispravili bas obradovalo.
Uostalom znas kako se kaze, don't fix if it ain't broken.
Ja skinuo novi firmware, za svaki slučaj, ako krene da greši.
Za sada radi sve kako treba, tako da.... što bi rekao audio: "don't fix if it ain't broken".
Ma to onako,manijacki:D
