Trazio sam po forumu, ali nisam nista slicno nasao:
Imam problema sa pokretanjem Call of Duty-ija!
Instalirao sam igru, overwriteovao, coDSP.exe fajl, i nece da mi se pokrene.
Prvo izbaci poruku:
"configure.csv: "cpu mhz" should be the first column",
zatim mi se otvori Call of duty console prozor u kome pise:
[code:1]
COD 1.0 build win-x86 Oct 5 2003
----- FS_Startup -----
Current language: english
Current search path:
C:\PROGRA~1\CALLOF~1\main\pak6.pk3 (3 files)
C:\PROGRA~1\CALLOF~1\main\pak5.pk3 (4858 files)
C:\PROGRA~1\CALLOF~1\main\pak4.pk3 (1668 files)
C:\PROGRA~1\CALLOF~1\main\pak3.pk3 (1992 files)
C:\PROGRA~1\CALLOF~1\main\pak2.pk3 (694 files)
C:\PROGRA~1\CALLOF~1\main\pak1.pk3 (2642 files)
C:\PROGRA~1\CALLOF~1/main
C:\PROGRA~1\CALLOF~1\main\localized_english_pak1.pk3 (3736 files)
localized assets pak file for english
C:\PROGRA~1\CALLOF~1\main\localized_english_pak0.pk3 (1204 files)
File Handles:
16797 files in pk3 files
execing default.cfg
execing language.cfg
Unknown command "cpu"
Unknown command "1840,"
execing config.cfg
execing autoexec.cfg
========= autoconfigure
----- CL_Shutdown -----
Hunk_Clear: reset the hunk ok
configure.csv: "cpu mhz" should be the first column[/code:1]
Da li neko ima taj fajl (configure.csv) da mi ga posalje.
Ja sam pokusao da ga napravim ali ne ide.
Imam bartona 2500+, 512 ddr, ati 9200
btw: nisam nasao ni fajlove autoexec.cfg,default.cfg... nigde (u dir-u)
hvala
Prvo izbaci poruku:
[code:1]
File Handles:
execing default.cfg
execing config.cfg
hvala
