- Intel® Core™ i3-13100F
- ASUS TUF GAMING B760M-PLUS D4
- Kingston 32GB DDR4 3600MHz
- ASUS DUAL GTX 1060 OC
- Samsung 990 Pro 1 TB
- Zvuk
- Fiio K5 Pro ESS + HD 58x
- CM G550M
- Fractal Design Define R5
- Monitor
- LG 27GR83Q-B
- Miš & tastatura
- Logi M330 & HyperX Alloy Core RGB
- Mobilni telefon
- Samsung S23 Ultra
- Pametni uređaji
- Samsung Galaxy Watch 5
- Kablovski internet
http://www.cdrinfo.com/Sections/News/Details.aspx?NewsId=11537
Taiwan ODD makers may begin production of 4x DVD+R/-R DL burners in Q1 2005
Leading manufacturers of optical disc drives (ODDs) in Taiwan will raise the writing speed of DVD+R DL (single-sided double-layer) burners from 2.4x to 4x, perhaps as soon as the first quarter of 2005.
Taiwan makers will also upgrade the writing speed for DVD+RW/-RW from 4x to 8x, the makers noted.
In addition, the DVD Forum recently approved the DVD-R DL format at 4x writing speeds, and makers indicated that more vendors will begin producing 4x DVD Dual (+R/-R) DL burner models.
However, because 8.5GB DVD+R DL discs are expensive, and the additional production costs for drives that support DVD+R DL are quite high, some 16x DVD Dual burner models do not support DVD+R DL, so some vendors may not include DVD-R DL support in their optical drives as well.
(From DigiTimes)
(From DigiTimes)
