Sasa_NS je napisao(la):Jesi li mislio na ovo?
*#3370# - Enhanced Full Rate Codec (EFR) activation. It will automatically restart.
*#3370* - Enhanced Full Rate Codec (EFR) deactivation. It will automatically restart.
*#4720# - Half Rate Codec activation. It will automatically restart
*#4720* - Half Rate Codec deactivation. It will automatically restart
Enhanced Full Rate will give you much better sound quality when you enable it. The new Enhanced Full Rate CODEC adopted by GSM uses the ASELP (AlgebraicCode Excitation Linear Prediction) compression technology. This technology allows for much great voice quality in the same number of bits as the older Full Rate CODEC. The older technology was called LPC-RPE (Linear Prediction Coding with Regular Pulse Excitation). Both operate at 13 kilobits.(but you take up more space on the network, so they can charge you more) - Talk-time is reduced with about 5%
Ali pazi, to je bio nekada štos za starije GSM telefone, nisam siguran da li to uopšte funkcioniše na novijim modelima...
Misa® je napisao(la):Probao sam i radi na 6100, ali ne vidim nikakvu razliku...
