Bart PE problem
angus
Kako resiti sledeci problem:
Processing driver IDs
Checking for missing files
Error: File "D:\Program Files\Bart PE\pebuilder3110\PE Win\I386\SYSTEM32\NTOSKRNL.EXE" not found
Builder has stopped because there are 1 build errors
ISO image is not created, you must fix the errors!
probaj da ručno ubaciš fajl koji mu fali.
da li si koristio oem winxp sp2 disk ili neku drugu verziju ?
Probao sam i rucno,ali nece.Win je SP1
v3.1.10a
Bugfix release
PE Builder would report,
File "C:\pebuilder3110\BartPE\i386\system32\NTOSKRNL.EXE" not found,
on some older windows versions.
dakle, skini noviju verziju.
onako usput, da li imaš neki jak razlog kojeg ne koristiš sp2 ?
@angus
radi ?
