ati 1600pro i OpenGL
sulumper
Pozdrav svima,
Imam instaliran XP sp3 x86 i W7 ultimate x86, sveze instalacije, stabilni sistemi, poslednje verzije drajvera.
Graficka je radeon 1600pro, igricama se ne bavim tako da ne bih ni primetio problem da nisam pokusao da ukljucim opengl support u photoshopu.
Pod XP-om sve to funkcionise, dok pod W7 kaze da ne podrzava.
Skinem ja OpenGl extension viewer http://www.realtech-vr.com/glview/index.html i imam sta da vidim
XP
Renderer: Radeon X1600/X1650 Series
Vendor: ATI Technologies Inc.
Memory: 256 MB
Version: 2.1.8543 Release
Shading language version: 1.20
Core features
v1.1 (100 % - 7/7)
v1.2 (100 % - 8/8)
v1.3 (100 % - 9/9)
v1.4 (100 % - 15/15)
v1.5 (100 % - 3/3)
v2.0 (100 % - 10/10)
v2.1 (100 % - 3/3)
v3.0 (39 % - 9/23)
v3.1 (12 % - 1/8)
v3.2 (0 % - 0/9)
OpenGL driver version check (Current: 6.14.10.8543, Latest known: 6.14.10.6847):
Latest version of display drivers found
According the database, you are running the latest display drivers for your video card.
W7
Renderer: GDI Generic
Vendor: Microsoft Corporation
Memory: 256 MB
Version: 1.1.0
Shading language version: N/A
Core features
v1.1 (100 % - 7/7)
v1.2 (12 % - 1/8)
v1.3 (0 % - 0/9)
v1.4 (0 % - 0/15)
v1.5 (0 % - 0/3)
v2.0 (0 % - 0/10)
v2.1 (0 % - 0/3)
v3.0 (0 % - 0/23)
v3.1 (0 % - 0/8)
v3.2 (0 % - 0/9)
OpenGL driver version check (Current: 1.1.0, Latest known: 1.1.0):
ispostavi se da stvarno pod W7 OpenGL funkcionise u verziji 1.1 dok pod XPom 2.1
Ima li resenja za ovaj problem (sem zamene hardvera)?
U GLView u glavnom toolbaru na vrhu imas da biras OpenGL implementacije u combo boxu. Pogledaj tu da li ima jos nesto.
Samo da javim resenje.
Mora da se instalira kompletan control center, ne samo drajveri kao sto sam ja uradio.
