Alliance of Valiant Arms - A.V.A
Jovyland
VIP član
CPU & Cooler
Ryzen 5 5600
Matična ploča
MS B350M Mortar Arctic
RAM
16GB DDR4 HyperX 3200Mhz
GPU
XFX Qick RX 6700XT
Storage
1 TB SSDa + 3TB HDDa
PSU
Seasonic MII EVO 520W
Monitor
DELL G2724D
Laptop
HP Pavilion Aero 13
Steam
jovyland
Pristup internetu
  1. Optički internet
  2. Mobilni internet
Besplatan online takticki FPS smesten u blisku buducnost koji prati konflikt izmedju EU i Neo-Ruske Federacije. Igra koristi UT3 endzin, a closed beta traje od 23. septembra.
Utisci igraca su uglavnom pozitivni, a srz igre je timski rad.
Alliance of Valiant Arms will launch Closed Beta on Wednesday September 23, 2009. Although it is closed beta, it is open to everyone. Everyone can play only between the hours of 12:00pm ~ 8:00pm (PDT). Everyone is welcome from all regions over the world except for Korea, China, and Japan because there is already a service provider in those regions.
E3 2009: Alliance of Valiant Arms
South Korean free-to-play online shooter is coming to the US.
[YOUTUBE]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/ICHaSjDp1zE&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/ICHaSjDp1zE&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/YOUTUBE]
US serveri = 130 ping = neigrivo
Igrao sam closed betu, preveliki je lag bio. Open beta pocinje 14.10. pa probajte a na forumu rekose da ce mozda biti i Evropski server jednog lepog dana.
Lag je veliki ali igra je do jaja. Stvarno steta sto nema EU servera (mada znajuci ijji tesko da ce ga biti). Ova igra pripada novom talasu F2P igara sto nam stizu iz Koreje i ne moze se porediti sa matorim F2P FPSovima, jednostavno odskace isto kao i Huxley.
Gameplay je ultra brz, nema mnogo razmisljanja, oruzje je odlicno uradjeno (koliko ja mogu da procenim). Mnogo me podseca na SWAT i Rainbox Six igre, znaci uletis, ubijes ili budes ubijen u 2 sekunde.
Graficki izgleda odlicno (UE3 engine) i stoji rame uz rame sa CoD4. Ima zanimljive modove kao sto je Escort gde je cilj cuvati tenk dok ne dodje na odrediste, naravno tu su Demolition (postavljanje C4 i defuse, good ol' CS) kao i Annihilation mod koji je cini mi se klasican TDM.
Sve u svemu odlicna igra, kad bi postojala mogucnost pravljenja piratskih servera bilo bi super. Posle igranja CrossFirea, WolfTeama i slicnih papazjanija ovo mu dodje ko melem na ranu.
Jedina veca mana koju sam zapazio jeste nedostatak leana i to mi bas smeta.
Kako da skinem igru da probam i ja;)
Open Beta Client
P.S. Ja sam imao solidnih problema sa lagom ali meni net ceo dan radi lose (SBB). Ako ne budes imao problema sa netom kao ja trebao bi imati oko 130 ping sto je donekle igrivo mada postoji delay (nigde ne pise koliki je ping ali ja znam iz iskustva igranja na US East serverima).
Edit: Eh da, svaka ijji igra smara kod pokretanja tj. moras u browseru pre pokretanja da se ulogujes pa tek onda start game (isto iz browsera). Ima opcija instaliranja nekog reaktora koju pojednostavljuje stvari ali je s druge strane dodatni software (ja sam ga instalirao ionako mi je Win u haosu :D). Takodje ne zaboravi da iskljucis Purple Bean aplikaciju kad pokrenes igru (ALT+TAB, ubijes Purple bean iz system tray a preporucujem isto i za Reactor ako se odlucih na instalaciju istog). Sve to da bi bio siguran da neki od tih servisa/aplikacija ne vuce nesto s neta i zeza ti ping.
A jel igra neko ovo? Ja sam probao par sati i sta znam, ne moze da se poredi sa bf2 i cod-om, ali opet kad je za dzabe vredi probati.
Meni se vise dopada od CoDa, realnije je pucanje i grafika je cista kao u CSu, nije onako pretrpana ko u CoDu. Sa BFom ne moze da se poredi, to se slazem. Ovo nije igra na fazon BFa vec CSa i CoDa. Kako tebi radi? Jel imas puno laga ili je igrivo?
Ja sam hteo da probam ovu igru, ali imam problema sa kreiranjem naloga na ijji.com.
Čim kliknem na "sign up", bilo gde (ijji.com, ava.ijji.com ili ijji reactor) uvek dobijem poruku:
You don't have permission to this page on this server.
Explanation:
We are sorry but you are not eligible to use ijji.com
If you believe this is incorrect, please contact Customer Help
Probao sam na dva kompjutera i to iz XP-a, Viste i Linux-a... uvek isto.
E onda sam zatražio od burazera iz Nemačke da mi on kreira nalog, što je i učinio bez problema, međutim, kad god pokušam da se prijavim sa tim nalogom, javlja:
The page cannot be found
Explanation:
The page you are looking for might have been removed, had its name changed, or is temporarily unavailable.
Please try the following:
1. If you typed the page address in the Address bar, make sure that it is spelled correctly.
2. Open the Home page, and then look for links to the information you want.
3. Click the Back button to try another link.
If the problem persists, please contact Customer Help for assistance.
Pritom mi ovo javlja šta god da upišem kao nalog i šifru, dok moj burazer može manje više komotno da se prijavi i odjavi sa nalogom koji je kreirao...
Ima li neko bilo kakvu ideju šta se ovde dešava?
Ovo mu dodje kao nesto izmedju CS-a i CoD4...
[YOUTUBE]<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/iiscb3gtHpE&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/iiscb3gtHpE&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>[/YOUTUBE]
Ni ja ne mogu da se registrujem. Proxy ne pomaze. Vi koji igrate, kako ste otvorili naloge? Mozda postoji neki rok koji je istekao?
Pa sta znam, ima laga, al opet mi je i to igrivo jer sam naucio na te probleme sa netom. Ako igras daj username pa da se nadjemo na nekom serveru.:)
Ni meni nece da se rega sve sam poskido sto trazi xfire,reactor to sve radi ali ne moze nalog da se napravi:S:
Namestio sam probajte resetovati modem;)
Evo ovako igra je vrhhhhhhhhhhh.Unreal 3 engine znaci grafika vrh uz ogroman fps sve na max 80+ fps.Gameplay je mesavina CoD i CS znaci cak je nisan ko u CS-u.Za besplatnu jednu igru ovo je odradjeno bas profi tako da vredi sigurno probati igra je vrhhhh;)
Name u igri mi je kratko i jasno Srbin.Nema laga ,servera ima dosta uglavnom su dobro popunjeni.
E sad sto se tice Acc na onom sajtu ni meni nije hteo da napravi acc ali sam zamolio druga u hrvatskoj da proba on je napravio acc poslo mi pass i name i ja sam probo nije htelo prvi put izbacuje erorr.Onda sam resetovo svoj modem pa onda probo njegov acc i radiiiiiiiiiiiiiiiiiiii probajte tako uradite reset modema;)
Originalan ti je nick ,) sve razumem ali to stavljanje srb, cro bih na nickovima mi nikad nije jasno ... kontam pacenici ;)
Tnx:D jel ti igras ovu igru?
A sto se tice laga jos nisam naiso na neki lag da nije igrivo tako da ludlo totalno igra otkida;)
Stvarno steta sto je ova igra F2P. Da je retail ja bi ovo kupio i igrao na nekom lokalnom serveru. Ovako nema sanse, u toku partije mi se bar dvaput zabaguje net i ne mogu da radim nista 30 sec. Sto je najgore nekad nece da se sredi samo od sebe i tad moram da napustim partiju. Ovaj SBB od kako je povecao ove brzine je postao takav junk net da je to strasno.
Drugi problem, takodje vezan za F2P jesu hakeri i oni obicno dolaze iz Juzne Amerike. Nikad nisam mrzeo druge nacije ali zbog F2P igara ne podnosim narode Latinske Amerike. ****ga a stvarno je dobra igra :(
Ovo mi je definitivno najbolji free-to-play online FPS u moru slicnih koji su se pojavili poslednje dve godine.
Da Da ovo je vrh posto sam igro CSS(css igram i dana danas lol) i cod 4 mogu reci da je ovo spoj ta dva znaci idealno;)
Sto se tice pinga imam adsl telekom 2mb i ima jedno 10 tak servera gde je ping ispod 100 sasvim dovoljno nema laga;)
Da sve je to super samo sto ona registracija jako smara i ne mogu nikako da je resim... drugar se registrovao umesto mene ali ja ne mogu da se logujem nikako resetovao sam modem 10x... u pitanju je PTT cable :(
pih majku mu ni ja ne mogu da se registrujem.......ne kapiram u cemu je sugavi problem
Ajde da se okupimo poslepodne ili veceras, pa da odigramo koju partiju, samo da se uklopimo oko termina. :)
ja večeras igram l4d2
može za vikend, ja sam za, svući ću ga začas sa neta...
Pa oni koji su preorderovali original na steamu imaju pristup demo-u od večeras :)
