AGP Texture acceleration : not available
koma
Kad startujem DXDIAG ova opcija je "zasivljena", ne moze da se menja.
Komp je MSI KT4AV, Sempron 2300+(oc na 2600+), Radeon 9550 128 MB, 128 bit. 256 MB ram ostalo nije vazno....
Probani razni drajveri (catalyst, via 4in1...), upgrade biosa, menjan aperture size u biosu, a sve je to na Win XP SP2 sa svim update-ovima instaliranim.... i nece pa nece....
Default rezultat u 3dmark03 upd340 je 2200, a u 3dmark01se je 7200.
Ima li neko ideju sta tu moze da bude u pitanju ?
Pozdrav,
probaj:
Texture Acceleration.
If you are lacking Texture Acceleration (this can be diagnosed via DXDIAG; Start -> Run -> DXDIAG -> Display) there are several troubleshooting steps you can try.
First off, right click your desktop and hit 'Properties.' Select Settings, Advanced, then Troubleshoot. Make certain that your Hardware Acceleration is ALL the way to the RIGHT.
Now head over to Start -> Run -> SMARTGART (the advanced SMARTGART settings). If everything is off, you've got problems; some might be on, others off; or they might all be on. Regardless, hit "Retest All." You'll need to reboot; but before you do, head over to your motherboard's website and get the LATEST AGP and Chipset drivers, in addition to FlashBIOS updates.
Restart now; it's unlikely you will still have the problem. If you do, try reinstalling your ATI drivers via the System Purging procedure, and then perhaps re-installing DirectX 9.0b.
vise o tome:
http://www.rage3d.com/board/showthread.php?t=33738545
via4in1 drajveri za plocu treba da se instaliraju
Probao sve fore i fazone i na kraju zakljucak kartica je neispravna ili se jednostavno ne slaze sa plocom, stavljanjem Radeon-a 9000 sve je iz prve proradilo...
Pozdrav,
meni se to desavalo kad nisam imao instalirane drajvere za plocu...
i meni su 4in1 pravili probleme.... do toga je 100%
