Pitao sam profesionalnog fotografa, on kaze da je u pitnju setovanje izmedju sRGB i Adobe RGB u photoshop-u i da li ti je ukljucen adobe gamma (Nalazi se u Control Panel-u).
Mora da su usaglaseni svi parametri, sto zanaci da ti na aparatu podeseno Adoba, u Photosop-u radno okruzenje Adoba RGB i da ti je ukljucen Adoba Gamma ili obrnuto sa sRGB.
Mali dodatak Adobe vs sRGB:
When should aRGB be used?
If you shoot RAW and convert to 16 bit TIFF, skipping JPEG all the way, then, if you have your editing suite properly profiled, go ahead and use aRGB. You most likely know what you are doing and even if you don’t really benefit from using aRGB at least you will not be hurt by using it. Just remember to convert to sRGB for anything that will be displayed on the web or shared via email. Also always verify what color space is expected when sending out files for printing.
