Потребан програм који додаје датум модификације у име фајл
David.1992
Poštovan
RAM
16GB DDR4
Storage
240 GB SSD, 1TB HDD
Mobilni telefon
MOTOROLA moto g24 Power 8/256GB Ink Blue
Pristup internetu
  1. ADSL
Треба ми програм који ће датум модификације унети у име фајла.
Претпостзављам да то може било који програм за преименовање фајлова, нпр. KRename.
А могу и фајл менаџери, нпр. FreeCommander.
Što kaže Djole - Total Commander.
Selektuješ fajlove kojima hoćeš da promeniš ime, pa CTRL+M na tastaturi.
Ovo bi trebalo da može baš to što ti treba, jer može po dosta kriterijuma da odradi, pa pogledaj...
Bulk Rename Utility: file renaming software for Windows. Bulk Rename Utility is free of charge for personal, private use, at home. To use Bulk Rename Utility within a business entity, company or for commercial purposes, a commercial license is required.
Bulk Rename Utility allows you to easily rename files and entire folders based upon extremely flexible criteria.
Add date/time stamps, replace numbers, insert text, convert case, add auto-numbers, process folders and sub-folders... plus a whole lot more! A file renaming studio for Windows.
  • Rename multiple files quickly, according to many flexible criteria. Learn More
  • Rename files in many ways: add, replace, insert text into file names. Convert case, add numbers. Remove or change file extensions.
  • Check the detailed preview before renaming.
  • Rename photos using EXIF metadata (i.e. "Date Picture Taken", "Resolution" and other information embedded in all JPG photo files) Rename your holiday pictures from a meaningless dsc1790.jpg to NewYork1.jpg in a flash.
  • Rename MP3 files using ID3 tags (a.k.a. MP3 ID3 tag renaming).
  • Rename files using Windows File Properties (e.g. media video length, width, height, rate, publisher, etc).
  • Change files' creation and modification time stamps.
Ili eventualno ovaj..
Datetime modified tags
Use these tags to insert the modified date or time of the file. These work the same way as the Date/Time Created Tags. All tags except <Year Modified> have a length of two characters at all time.
<Date Modified:format>
<Time Modified:format> See <Date> tag for a description of the parameter.
<Sec Modified>
<Min Modified>
<Hour Modified>
<Day Modified>
<Month Modified:x> See <Month> tag for a description of the parameter.
<Year Modified:x> See <Year> tag for a description of the parameter.
<UnixTimestamp Modified>
These tags also support adjusting output value.
