" Model numbers 3800+, 3500+, 3200+ and 3000+ in socket 939 only will be affected by the new revision change from E3 to E6.
The E6 revision is pin to pin compatible with the current E3 revision, and will function in existing platforms based on 939 pin AMD Athlon(tm) 64 processors, but a new BIOS will be required to recognize the new CPU ID (Current CPU ID will change from 00020FC0h to 00020FC2h).
This new revision is expected to start shipping from July 15th 2005 and the marking of the affected model numbers will change as shown below:
MODEL NUMBER PREVIOUS PIB REF NEW PIB REF
3800+ ADA3800BPBOX -> ADA3800BWBOX
3500+ ADA3500BPBOX -> ADA3500BWBOX
3200+ ADA3200BPBOX -> ADA3200BWBOX
3000+ ADA3000BPBOX -> ADA3000BWBOX
Source: AMD email.
OK, ko je raspolozan za jos mesec i po cekanja?! Neka se javi
U medjuvremenu da vidimo sta mogu E3 revizije!
Oznaka procesora OPN Frekvencija Voltazza Hladjenje
3000 - CBBLE 0504DPAW - 2800 - 1.616 vazduh
3000 - CBBLE 0504DPAW - 3000 - 1.648 fazna promena
3000 - CBBLE 0512DPAW - 2902 - 1.500 vazduh
3000 - CBBLE 0512DPAW - 2700 - 1.360 vazduh
3000 - CBBLE 0512DPAW - 2857 - 1.632 vazduh
3000 - CBBLE 0512DPAW - 2880 - 1.520 vazduh
3000 - CBBLE 0512DPAW - 2800 - 1.520 vazduh
3000 - CBBLE 0512DPBW - 2922 - 1.580 vazduh
3000 - CBBLE 0512DPBW - 2826 - 1.500 voda
3000 - CBBLE 0512DPBW - 2901 - 1.680 voda
3000 - CBBLE 0512DPBW - 2916 - 1.664 voda
3000 - LBBLE 0516CPBW - 2700 - 1.664 vazduh
3000 - LBBLE 0516CPBW - 2765 - 1.744 vazduh
3000 - LBBLE 0516CPBW - 2700 - 1.488 vazduh
3000 - LBBLE 0516CPBW - 2808 - 1.664 vazduh
3000 - LBBLE 0516CPBW - 2610 - 1.568 vazduh
3000 - LBBLE 0516CPBW - 2475 - 1.472 vazduh
3000 - LBBLE 0516CPBW - 2700 - 1.400 voda
3000 - LBBLE 0516CPBW - 2765 - 1.648 vazduh
3000 - LBBLE 0516CPBW - 2450 - 1.520 vazduh
3000 - LBBLE 0516CPBW - 2610 - 1.488 vazduh
3000 - LBBLE 0516CPBW - 2700 - 1.552 voda
3000 - LBBLE 0516CPBW - 2600 - 1.632 voda
3000 - LBBLE 0516CPBW - 2630 - 1.536 vazduh
3000 - LBBLE 0516EPAW - 2700 - 1.520 vazduh
3000 - LBBLE 0516EPBW - 2160 - 1.400 vazduh
3000 - LBBLE 0516EPBW - 2860 - 1.730 voda
3000 - LBBLE 0516EPBW - 2800 - 1.600 voda
3000 - LBBLE 1516EPHW - 2700 - 1.504 vazduh
3000 - LBBLE 0516GPBW - 2808 - 1.552 voda
3000 - LBBLE 0516CPCW - 2610 - 1.650 vazduh
3000 - LBBLE 0516CPCW - 2600 - 1.550 vazduh
3000 - LBBLE 0517EPAW - 2700 - 1.475 vazduh
3000 - LBBLE 0517EPAW - 2925 - 1.522 vazduh
3000 - LBBLE 0517EPAW - 2961 - 1.616 vazduh
3000 - LBBLE 0517EPAW - 2781 - 1.480 vazduh
3000 - LBBLE 0517EPAW - 2942 - 1.580 voda
3000 - LBBLE 0517APIW - 2800 - 1.440 vazduh
3000 - LBBLE 0517APIW - 2700 - 1.360 vazduh
3000 - LBBLE 0517BPMW - 3000 - 1.720 vazduh
Source: AMD email.
