Milan
Delija je napisao(la):Ako ti nije problem zakaci tvoj konfig!
Inace, nemam instaliran Catalyst 4.9, vec Omega 2.5.67 (4.8 + OpenGL ver4.9).
Mislis na Performance za Anti-Aliasing ili za Main Settings (ATI control Panel->OpenGL)? Ja sam tu ostavio na app.controled, posto sam primetio da imam par frejmova vise kada ukljucim AA iz same igre. A stuca mi zbog ucitavanja sa harda. Da budem iskren, igru nisam igrao par dana, vec sam se samo zezao sa timedemo-om i onaj prvi prolaz je kriminalan!
Evo ti procedura i fajl:
1. Apply Humus updated tweak.
2. Install catalyst beta 4.9b, or place 4.9b atioglxx.dll in doom3 and/or(?) base directory, if you're using an older driver.
3. Apply AF through control panel or radlinker.
4. change image_anisotropy to "1" in doom3config.cfg.
Now I can have 16x AF with better framrates than I had with 2x before. (a little boost from 4.7 -> 4.9 also helps)
Although, when I tried quality AF, the fps dropped like it normally would. So it seems performance AF is the "free one", but that's good enough for me.
