Pozdrav drugari,
Vec nekoliko dana na mom laptopu desava se cudna stvar koja nije nikad do sad. (Koristim laptop sa GTX1080 i CPUi7-7820HK.) Tokom igranj neke igre ili gledanja filma itd... laptop sam od sebe pokrene u sleep modu tacnije - pojavi se text LOCK i animacija loadinga i lagano se ugasi i onda moram ga ponovo da upalim laptop i on nstavlja tamo gde je stao. Temperatura nije visoka, nekad ide 70 ili oko 80, kako na CPU tako i na GPU(mada na GPU uvjek manje). Ne shvatam sta mu se desava, ne pregrijava se mnogo da se ovo desi. Ali evo u Event Viewer sta sam nasao:
1. Error Source: ACPI Event ID: 13
(ovakvih istih se nalaze 4 u redu jedan za drugim i to sve za 30 sekundi)
: The embedded controller (EC) did not respond within the specified timeout period. This may indicate that there is an error in the EC hardware or firmware or that the BIOS is accessing the EC incorrectly. You should check with your computer manufacturer for an upgraded BIOS. In some situations, this error may cause the computer to function incorrectly.
2. Error Source: Kernel-Power Event ID: 88 Task Category: 85
(ovakvih istih se nalaze 2 u redu jedan za drugim)
The system was hibernated due to a critical thermal event.
Hibernate Time = 2020-04-24T16:04:16.144944000Z
ACPI Thermal Zone = \_TZ.TZ01
_HOT = 373K
3. Information Source: Kernel-Power Event ID: 42 Task Category: 64
The system is entering sleep.
Sleep Reason: Thermal Zone
4. Information Source: Power Troubleshooter Event ID: 1
The system has returned from a low power state.
Sleep Time: 2020-04-24T16:04:16.139385300Z
Wake Time: 2020-04-24T16:05:09.697491400Z
Wake Source: Unknown
Bas jutros (ali ne po prvi put) gledam seriju Vikinge, nakon 20 minuta samo ode u LOCK mod i moram ga ponovo palit. Nekad izdrzi10 minuta, nekad 30 minuta, ali uvjek je to u zadnjih nekoliko dana.
Na Msi Afterburn i Hwinfo64 nisam mogao naci podatak o velikoj temperaturi. Windows 10 Pro je updejtovan.
Bio bih Vam veoma zahvalan na pomoci.
_HOT = 373K
